Old 01-22-2016, 09:39 AM   #1
bovi
Pedal 2 The Metal
bovi's Avatar
Drives: 2010 2SS/RS E-Force 6XXwhp
Brake fluid Leaking from transmission
Hi guys,
Just before i stored my car for winter, i was driving to my house and the last 200-300m, my clutch pedal stayed to the floor. I parked the car, looked at the brake fluid reservoir and it was a bit low. I've filled it and when i was pressing the clutch manually and putting it back up, the brake fluid was coming out of my bellhousing.
Didn't opened it yet but i would like your advice on this.
Slave cylinder???
Camaro '10 ZL700 Package
Edelbrock Supercharger with 3.25''pulley
Custom Grind Cam
Kooks Headers
American Thunder Exhaust
Rotofab Intake
Lingenfelter Twin Pump 1000
bovi is offline   Reply With Quote
Old 01-22-2016, 09:47 AM   #2
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
Slave is most likely the case. Possibly the line is loose. Maybe a mouse ate its way through the hose before it transitions to a hard line? Only way to know is to start a detailed inspection. I would start at the reservoir and work your way down to the bell housing before start looking at pulling the transmission for the slave.
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 01-24-2016, 08:47 AM   #3
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Most likely the slave cylinder
camarosspower is offline   Reply With Quote
Old 01-24-2016, 03:35 PM   #4
MustangKiller
MustangKiller's Avatar
Drives: 2013 2ss/rs A6 yellow !!!!!
Yes or best case the bleeder screw on the slave is loose
Sent from my SM-N920T using Tapatalk
MustangKiller is offline   Reply With Quote
Old 01-29-2016, 11:58 AM   #5
Skyblu
Skyblu's Avatar
Drives: 2010 Aqua blue 2SS/RS M6
would this also affect the brake pedal too since they use same resevoir? The issue I am having is sometimes especilally on start up I get a hard brake pedal and then the clutch pedal feels weird too like not depressing all the way. The resevoir was low, I filled it about 3 days ago and seemed better until today now doing the same thing. I don't notice any leaks though.
Skyblu is offline   Reply With Quote
Old 02-07-2016, 11:05 AM   #6
Merc
In The Circle
Merc's Avatar
Originally Posted by bovi View Post
Hi guys,
Slave cylinder???
It could be the plastic bearing support going away in the slave cylinder. If so you should replace that with the Monster Clutch billet piece and install a separator resivour for the clutch slave while your at it.
Old 02-09-2016, 03:15 PM   #7
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
OP If the fluid is coming out of the vents at the bottom of the bellhousing, slave is the most likely culprit. Regardless, you new to pull the trans to see the problem
Post what you find. I haven't heard of a slave blowing a seal without other issues ie heat
h018871 is offline   Reply With Quote
