05-09-2024, 10:05 PM | #1 |
Drives: 2020 Camaro SS 1LE | Satin Steel Join Date: Jan 2022
Getting ready for first start
I am getting ready to do my first start/crank since installing my cam. Its full of fresh Driven Oil DI-30. A few questions:
When installing the ATI damper, how many times can I use the stock bolt to install the damper, as per the instructions. I have already used it to install the damper once. Will a second time break it? Is it okay to crank or start the car with no water in it? I want to do this in case I have to pull the water pump off again, I don't want to bother draining the radiator. Cam timing. I am fairly certain I got cam timed correctly, but I am still nervous since I didn't remove my oil pump and couldn't see the timing dot. My process for determining alignment is as follows: The location of the timing dot is a specific distance counter clockwise of the keyway for the crank. And ALL crank sprockets should have the keyway and timing dot in the same place. I figure this means that I am lined up with the timing dot. The engine turns over with a wrench and doesn't get stuck anywhere (no spark plugs in).
GPI SS3 / GPI ported heads | MSD Atomic / NW 103mm | 1 7/8th LTH | Roto-Fab CAI | FlexFuel | Tuned by GPI |
xxx Hp / xxx tq |
05-09-2024, 10:19 PM | #2 |
Gray Ghost
Drives: 24 Camaro 2SS Loaded Join Date: Feb 2024
^^^^ no help but,,, way cool!! Best of luck and congrats!! Hope to see a video directly of that car running so we can hear the new (er) motor
05-10-2024, 05:09 AM | #3 |
Drives: 1977 Trans Am, 2024 Camaro 2SS Join Date: Apr 2023
Yes, you can crank and start it with no coolant in the system. I'd only run it for a minute or so in this configuration. Be sure to confirm that you have oil pressure then shut it down.
-Ray |
05-10-2024, 10:04 PM | #4 | |
xxx Hp / xxx tq |
05-10-2024, 10:34 PM | #5 |
Gray Ghost
05-10-2024, 10:51 PM | #6 |
Lol, we just ran it open headers. Didn’t want to put the full exhaust on since it was getting late and we were getting tired. Doing this install was definitely an experience and I learned a lot of lessons I feel. I would be more than happy to give tips and advice to those looking to do their own cam install. I did my install without even lifting the engine, as I didn’t really have the people or facilities or knowledge for that.
xxx Hp / xxx tq |
05-10-2024, 10:59 PM | #7 |
Drives: Camaro SS 1LE Join Date: Feb 2024
Sounds awesome congrats!
2018 Camaro SS 1LE (Garage Queen)
2000 Camaro SS FBO (Sold) 1996 Camaro Z28 (RIP) 2020 Mercedes A35 AMG (Daily) |
05-11-2024, 07:27 AM | #8 |
Gray Ghost
@Hostile_1LE
“Lol, we just ran it open headers. Didn’t want to put the full exhaust on since it was getting late and we were getting tired.“ Thought it was kind of loud for being in the engine room!! but still sounded gnarly!! |
05-11-2024, 08:01 PM | #9 | |
xxx Hp / xxx tq |
05-11-2024, 09:56 PM | #10 |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
05-12-2024, 06:11 AM | #11 |
Gray Ghost
He!! YA!!! Love it. that sounds just right! Awesome sound, and you should be very happy with that! Nice going!
