Old 12-18-2012, 04:32 PM   #57
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Originally Posted by L99BEN View Post
Couldn't one just use this to calibrate their speedo while leaving their factory tune intact?:
http://www.autoanything.com/performa...A3757A0A0.aspx
or
http://www.amazon.com/Hypertech-7320...SIN=B003CSQC86
Either way, it is an adjustment of the factory settings on the ECM, which in turn = loss of powertrain warranty in most cases (ask you local dealership to be sure).
blazzin1 is offline   Reply With Quote
Old 12-18-2012, 06:59 PM   #58
L99BEN
L99BEN's Avatar
Drives: 2023 BMW M4 Competition
I had my gears swapped on my 12' 5.0 with the speedo calibrated at the dealer and no effect on warranty. If I calibrated on my own using an SCT tuner for example, they may have had an issue with that since it involved a reflash.
I don't see how calibrating your a speedo would have an effect on your powertrain especially with a device specifically designed to calibrate the speedo only.
L99BEN is offline   Reply With Quote
Old 12-18-2012, 08:09 PM   #59
blazzin1
blazzin1's Avatar
Like I said, go talk to your local dealership, there are a few that are more lenient than others on this subject. Maybe Ford had a different policy? I just know I've heard it on here many, many times....ANY change to the factory settings on the ECM is an automatic void of the powertrain warranty in most cases. Call up your service manager at your dealership......and let us know what he says.
Old 12-18-2012, 10:07 PM   #60
L99BEN
L99BEN's Avatar
I hear you and will look into it with my dealer but nothing automatically voids your whole warranty just like that.
Old 12-20-2012, 11:26 PM   #61
jdogscam2013
Drives: 2013 2SS Blue Ray
I had a stock Formula in 1987, with a rare 3.73 gear option from the factory with a 350 tuned port injection and the car was freaky fast for the era. Rear end gears help a LOT. I would love to get another 3.73 with my 5th gen. It would make a difference.
jdogscam2013 is offline   Reply With Quote
Old 12-24-2012, 03:08 PM   #62
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
DANHR
THANKS FOR THE INFO FROM U AND EVERY ONE
SPOOKYGUNNER
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
Old 12-25-2012, 11:30 PM   #63
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Now that the 1LE has the 3:91 gears, I can't see why the dealer can't install then, while still maintaining the powertrain warranty, but then again like most have said I guess it depends on the dealer, but it's worth a shot.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 12-26-2012, 11:02 AM   #64
L99BEN
L99BEN's Avatar
You would think so and probably only for the manual and not auto since the 1LE only comes in manual
I had 3.73's installed in my 12 5.0 ( a factory option)and the dealer was cool about the overall powertrain warranty but if I had any issues with my rear end it would be on my dime...
Also make sure to find someone that knows what they're doing with gear installs. Ive had it done by so call experience professionals (one a dealer)and both times they made noise loud enough to hear over the radio.
Old 06-27-2013, 11:24 AM   #65
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Many thanks to danhr for this thread. I have a couple of questions as a result of all this good info.
1. So... the stock/factory gears in my 2013 SS L99 Coupe are 3.27s?
2a. Assuming the answer to #1 is yes, if I want "quicker" 1/4 miles times I should go to 3.47s or 3.73s?
2b. Which gears are optimal for increased times with excellent reliability?
3. For highway cruising (I take frequent trips), how will the higher gears (3.47s or 3.73s) affect MPGs, road noise, etc.
Thanks for any input.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 06-27-2013, 11:33 AM   #66
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
i went from 3.27 to 3.73 and saw appx 250rpm difference going 70
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 06-27-2013, 12:48 PM   #67
GQ4Life
Drives: 2010 Camaro SS LS3
If u have the traction 3.73 will. Help u getting out the hole a lot
i run 4.10s which make my gearing about the same auto with 3.73.. fine daily driving. I do 25k a year. MPG went down like 1 or 2.. considering these cars have wide gears its fine
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 09-23-2013, 08:19 PM   #68
aperfectcircle1992
Drives: 2010 infeno orange ss camaro
I'm looking for the torque spec for the rearend end caps and back lash
aperfectcircle1992 is offline   Reply With Quote
Old 11-13-2013, 01:16 PM   #69
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
wow .... I'm all confused
I already have a supercharger and a stall convertor .... would I see or feel anything by changing the gears on My A6 SS? Was going to try and get the 3.91's but now they are on back order and from this It sounds like I'm wasting my money with the whipple and stall already there
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 01-29-2014, 07:16 PM   #70
jdsblueray2013
Drives: 2013 Camaro 2ssrs Blue Ray
Send a message via Yahoo to jdsblueray2013
Wow man I forgot about that song, Bitchin Camaro, by the dead milkmen, remember hearing that for the first time back in the 80's when a buddy of mine with an 86 Mustang GT, brought a cassette into my car which was an 87 Formula 350, he said you have to hear this song by the DEAD MILKMEN, I thought it was a very cool song,
and was the last thing I expected to hear from a punk band like that! Thanks for posting it, brings back cool memories!
jdsblueray2013 is offline   Reply With Quote
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
Lowering springs and rear gears V6 information macwest 5th Gen Camaro SS LS LT General Discussions 12 04-30-2010 10:58 PM
rear end failure? xshortd Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 04-08-2010 06:59 PM
Changing rear end oil and trans oil? caverman Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 03-01-2010 10:09 PM
4:10 rear end or LT headers & tune? wildthing001967 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 02-06-2010 10:21 AM
