02-05-2023, 08:30 PM | #1 |
Drives: Camaro SS 1LE Join Date: Sep 2022
2018 SS 1LE Misfire issue, with mods
I have an 18 SS 6MT, it has been modified.
TSP cam, 660 valve springs Katech ported heads Corsa headers Corsa extreme exhaust LT2 intake LT5 throttle body E85 conv. Roto-fab intake I have slowly obtained a misfire. Then it got bad enough that it threw a code. Then it has the 'stabilitrak' code and service 'rear axle' code. The stuff I have done. replace plugs- cylinder #4 was showing a misfire and the plug was a little bit blacker than the rest. No change coils- replaced 2, 4, 6, & 8. No change noticed that #4 header tube was usually 200 degrees while idling when the others were 4-450. replaced spark plug wires. No change then finally replaced #4 fuel injector. No change. after all if this I did the CRC intake valve treatment, maybe it had excessive deposits (looked at it when I did the injector but did not look bad) No change Other bits of info. When it is idlin it is fine. When you are accelerating under roughly 20% throttle it pops and crackles, when you are aggressively accelerating it runs pretty good, almost like it should. I am running out of things to throw at it. Any suggestions? |
Tags |
1le, 6.2l, misfire |
