03-27-2023, 11:24 AM | #1 |
Drives: 2022 Camaro 2SS 1LE Join Date: Sep 2013
Supercharge Advise
I just picked up a 2022 2SS 1LE and I am super excited to be back in a Camaro! I had a 2013 SS for a few years but had to get rid of it for something more family friendly.
I love the car but I want to make some more power with it. This is a daily driver so I am not looking to go real crazy. I really don't want to dive into the internals of the engine if I don't have to so that's why I initially thought of a ProCharger setup. My goal is to end up somewhere in the 550-600WHP range if possible. Currently it is completely stock but I am also going to add a Corsa catback exhaust system. I was initially considering a ProCharger P-1SC-1 kit with a stage II intercooler and 7-8psi of boost but after reading some threads on here I am second guessing that now. I like the design and ease of installation not to mention how easy it is to put back to stock if need be. I would probably run the standard tune from ProCharger unless it was problematic. My concerns are if this will be too much for a SBE and 93 octane pump gas? I've read that this could put my compression too high and cause issues. I don't know of anywhere around me to get ethanol fuel other than E85 and I believe I would have to install a flex fuel kit as well. Also would I need to upgrade my fuel system at this level of boost? Is there anything else I should be considering or know about? Thanks in advance! |
03-27-2023, 11:39 AM | #2 |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
Is this your real end goal? (550-600WHP range)
Any plans to track/strip the car? (Assume that is why you bought a 1LE) As you mod the new car, you can kiss your powertrain warranty goodbye usually.. are you OK with that?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
03-27-2023, 11:43 AM | #3 | |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
I barely ran a 11.9@117 on the procharger setup, and it was a dangerous tune as I wasn't getting power enrichment at WOT. Really surprised I didn't break things. 93 octane and 11.5:1 compression is going to be your limiting factor to more than maybe 550 whp or so. Happy to go into more details on my own journey if that didn't put you off
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
03-27-2023, 12:06 PM | #4 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
If I was limited to 93 octane I wouldn't even supercharge a stock internal LT1...especially on a stock fuel system. Upgrade to the LT4 fuel system and run at least some VP octanium booster then you can start to make a little power safely.
Tech talk: Then you have to pray that you didn't get a LT1 engine with really tight ring gaps. I have a local shop that took one apart and found ring gaps as tight as .006. The leaves little to no room for heat expansion. Some will argue that Hypereutectic pistons don't expand and oil squirters will help. That is all true on a NA application. Add 7-8psi of boost on 93 octane and the gap on those piston rings will tighten during a long pull. If they tighten to the point where the ends butt, the piston with break. #7 is the common failure because it tends to run hotter. More Tech talk: Stock vs stock the older gen 4 LS3 will go further than a LT1 on boost because majority of those engines have at least .015 of ring gap. It does have similar material hyper pistons but overall, the LS3 has a weaker rotating assembly and those engines handle 850whp all day on boost. The reason being is because it's lower compression and has wider ring gaps. Don't want to offend, but upgrading to a ZL1 sounds like a better option for you based on the fact that you are worried about ease of returning to stock, limiting yourself to 93 octane, and wanting an easy power upgrade. Nothing gets easier than trading up to a ZL1 if the budget allows. Yes it's a bit more money but it's also going to be far more reliable on 93 octane.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
03-27-2023, 12:13 PM | #5 |
@jstanton- listen to what CJ and King have to say here... they will steer you in the right direction and save you a bunch of $$$ in the long run.... we have all been down this endless rabbit hole
03-27-2023, 01:26 PM | #6 |
Yes this is my optimistic goal. If I could get close to 550hp for my daily driver I would be happy. I have no intention of turning it into a track/strip car. Just trying to put a little more power to the ground and have a fun street car that's not the same as every other SS in my area!
03-27-2023, 01:38 PM | #7 | |
Before I jumped back on the forum and saw these response, I called ProCharger to ask some questions about this setup on a stock LT1 bottom end and fuel system. I was told that the P-1SC-1 with the HO or stage II intercooler was safe on my car without any modification to the fuel system and I shouldn't have any issues running their standard conservative tune. I'm just repeating what they told me. I understand there are variables they are probably not accounting for, like ring gaps as King stated, but I wanted to share what they told me. |
03-27-2023, 01:46 PM | #8 | |
Unfortunately a ZL1 is not in the budget right now. I found this car for a great price and couldn't pass it up. If I could run an ethanol fuel like E40 or E50 would that change your opinion on the subject? |
03-27-2023, 01:52 PM | #9 |
Drives: 2016 Camaro SS Join Date: Oct 2021
Might be too late but I agree with the other's a Zl1 would be your best bet.
If it is the SS then I would go full boltons for now add in a good flex fuel tune and be happy for a while. And if you keep feeling the urge for more power start by upgrading your fueling first then going with your power adder of choice. This way when you do add the power adder you have a platform that is more able to handle the HP.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
03-27-2023, 02:03 PM | #10 | |
2016 NFG 1SS A8
03-27-2023, 02:04 PM | #11 |
I am humbled to be named in the same sentence as KingLT1, but am ultimately undeserving
03-27-2023, 02:09 PM | #12 | |
My journey from 12's to 10's on the procharger: https://www.camaro6.com/forums/showthread.php?t=597270 Also my latest fueling adventure: https://www.camaro6.com/forums/showthread.php?t=613723
03-27-2023, 02:39 PM | #13 |
03-27-2023, 02:40 PM | #14 |
Tags |
1le, boost, procharger, super charger, supercharger |
