09-10-2023, 09:19 AM | #1 | |
Waiting 4 A Point By!
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon Join Date: Mar 2023
Trackday Alignment Gains for Road Atlanta!
I have to say I feel like an idiot for NOT doing the alignment sooner as I went to three different tracks, Atlanta Motorsports Park (more suited for a Miata than a ZLE), Barber Motorsports Park (finally got to open her up a bit but the blind hills with a bad alignment were Sketchy AF!) and my first run of Road Atlanta with a ZLE (I consider RA my "home track" with dozens of different cars and my best lap in a 1200whp Nissan GTR "street car" was a 1:30.9 lap).
If you have NOT done the alignment, DO IT! I ran the track day on a fresh set of Goodyear SC3Rs and had perfectly even wear across all four tires after 47 laps! Best previous trackday lap was a 1:40.3 and best lap a week later was a 1:36.2! There is a lot more in this car and my learning how to work with the nannies!
09-15-2023, 01:04 PM | #2 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Great video
This place is fairly close to me Hey how much would you estimate track insurance is for your Z ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
09-15-2023, 01:37 PM | #3 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
How much air pressure are you running when hot?
09-15-2023, 06:47 PM | #4 |
Shadow Gray '19 ZLE M6
You wanna keep SC3Rs under 37 PSI hot. I aim for 35-36 and I'll come in to bleed off air when they hit 37. They get greasy 37+.
Weather dependent, I go out at 26 or 27 PSI cold. Gotta take it easy the first 3 laps to get heat in the tires. Otherwise, you'll burn through cold SC3R tires if you push too early. It's also super easy to spin on cold tires.
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-18-2023, 08:41 PM | #5 | |
I corded the inside of my right front at Putnam Park a few weeks back. I'm pretty sure it was a combination of pushing too hard too soon and too low of air pressure. Learned the hard way I guess. In the late morning session they got up to 40 psi and seemed to do just fine. They didnt feel like they were rolling over in the turns like they did at 34 psi. The track wasnt real hot though. |
Tags |
1le, track alignment, zl1, zle |
