11-02-2018, 08:11 PM | #1 |
Drives: 2015 2SS Stock Join Date: Sep 2018
Please explain physics to me
So if I have a car and for arguments sake it makes 400 hp. People say figure 20% for drivetrain loss. Ok so 80hp. But if my car makes 800hp and you still say 20% drivetrain loss then the drivetrain now takes 160hp to turn! How does this translate? What in the flux compasitor is this witchcraft?
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
11-02-2018, 08:56 PM | #2 |
Started#gottalovethatblue
Subscribed for an answer.
11-02-2018, 09:06 PM | #3 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
e=mc^2
2011 2SS/RS built 8/24/10
11-02-2018, 09:25 PM | #4 |
Drives: 2015 Camaro convertible Join Date: Oct 2018
Ask someone with 800hp to go dyno their car and report back.
11-02-2018, 09:33 PM | #5 | |
Source: http://www.superstreetonline.com/how...in-power-loss/
416HP, 422TQ. Rotofab CAI, Dyno Tuned. ALP's and a V1. |
11-02-2018, 09:51 PM | #6 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
A stock L99 SS is about 22% loss at the rear wheel and the percentage lessens as peak HP increases. It’s also highly dependent on the transmission (obviously) so you can’t easily cross vehicles and just say 20%. It’s not a bad baseline though to be somewhat close.
11-02-2018, 10:34 PM | #7 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
Because the losses are mostly friction. This energy would be wasted mostly as heat, with some entropy changes (stuff grinding down). Same for brake pads but there is much more heat and entropy change (brake dust). Sometimes you push your brakes and scrub off 30hp and sometimes hundreds of hp. Some energy is wasted as light (glowing orange) or noise but that isn't a significant amount vs the heat in what you're asking.
Friction can actually go down as the speed increases but applying more force, as you do with your brake pads causes more friction...unless you're an ice skater and the blades melt the ice due to the pressure and friction and the water on ice reduces the friction. Doing unseen things like swirling around oils and fluids (including air) in the engine, trans, rear, and bearings are other examples of wasted energy aka friction. |
11-02-2018, 11:14 PM | #8 |
Drives: Miss Con Ception Join Date: Aug 2016
It has always been true that the more power you use, the more loss you see.
Lean on a drill and it's harder to turn.
2011 1SS/RS LS3 CGM
11-03-2018, 01:13 AM | #9 |
Was told by knowledgeable builders when I was building the 455 for my Cutlass that the 400 THM tranny robs 75hp. I didn't think to ask what a 350thm scrubs. I knew not to even try a 350 as my buddy w/a 396 Impala had already fried 2 350's without much effort.
11-03-2018, 06:32 AM | #10 | |
And Force = mass x acceleration but that doesn’t help here.
11-03-2018, 09:28 AM | #11 |
old school chevy rodder
Just so you know there are actually lock up converters and so much more like torque convertors with different rates of loss that calculating things out is a lot more complicated on a car by car basis with the varied parts.
A convertor btw slops around throwing the fluid with its little fins making pressure so imagine that...and imagine the torque getting to the wheels having to come from those little valves all over in the transmission flowing that fluid then transferring power through a couple u -joints to split off a gear to another gear that's attached to a pair of axles...…. And what kind of rear..... cause that matters.... a locker...a one legged dog.....etc now really blow your mind and figure the HP is measured off the torque...because torque is what moves you HP just says hey the engines this efficient making that torque...…… And you could have that 800 hp car with say 650 torque get its ass kicked by a car with 650 hp and 650 ft lbs of torque being lighter...kind of like lining up a ZL1 against a Hellcat.....or Demon..... wow how mind friggin boggling...LOL And yes of course if your even on a dyno measuring the loss and if its load bearing or full of SSSSSS...……...
11-03-2018, 11:20 AM | #12 | |
Big Crow
Interestingly the 2 speed powerglide transmissions of the 60s lost less hp. If you couldn't use the extra torque of more gears due to tire spin limitations, they were a better choice when built up for drag racing. |
11-03-2018, 11:27 AM | #13 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
The good news is, a study in 2010 (coincidence with introduction of the 5th gen?) suggests that the laws of physics as we know them, may not be the same in all parts of the universe. I’m thinking the HP gains in another sector could be huge! Or really parasitic.
11-03-2018, 11:42 AM | #14 |
"Cam Only"
734rwhp reporting back
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno) |
