Old 05-09-2012, 02:02 PM   #1
thecamaroguy
thecamaroguy's Avatar
Drives: 2020 ZLE 67 SS350
New Tires - New Issue
I receently got new REARS only Toyo Proxes 4 to replace my current Toyo Proxes 4 that I had on all four corners. 275/40/20 on Rear and 245/45/20 on Fronts.
The Fronts have about 1/2 life left, so I didn't put new ones on the front, while the rears were basically bald.
During the replacement, I got the Sensors replaced as well.
So, all good right...
I have had them on for about a week, and just noticed yesterday when I was driving and started to Exit the highway to and going on the Exit Ramp (Hard Right turn) my Traction Control would come on like I was slipping.
I thought that was odd, so I went back around (this time making a hard left) and nothing...but when I go hard right it kicks on.
I hope that makes sense....
What could the issue be?
Someone suggested because I didn't change the fronts, that the height of the tires from Front to Back are "out of spec" but wouldn't that cause the "slipping" to happen regardless if I'm turning Right or Left?
Plus, it is only on sharp right turns, not every right turn.
I'm lost as to what the issue might be.
Thanks,
thecamaroguy
2010 Camaro 2SS - CGM
1967 Camaro SS350 - Baldwin Motion Tribute
2020 Camaro ZL1 1LE - White
Proud to say I have always owned a Camaro! A Camaro has been my Daily driver since I started driving!
thecamaroguy is offline   Reply With Quote
Old 05-09-2012, 03:27 PM   #2
Group-A Wheels
Drives: Camaro SS
Thats very odd. The new tires on the rear versus the front tires wont be what is setting it office. Especially, after they have been on for a week with no issues. It sounds like you have some sort of traction control sensor issue, nothing to do with the tires.
I would bring it to the dealer
Group-A Wheels is offline   Reply With Quote
Old 05-09-2012, 03:54 PM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I would check your wheel sensors and wiring going to them.
SUX2BU is offline   Reply With Quote
Old 05-09-2012, 08:02 PM   #4
thecamaroguy
Where would that sensor be located?
Thanks,
thecamaroguy
Old 05-10-2012, 04:16 PM   #5
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Sounds like there is enough difference in diameter between the front and rears because of the wear difference to upset your traction control.
Rudy@Tirerack is offline   Reply With Quote
Old 05-10-2012, 04:37 PM   #6
Coyotekiller
Drives: 2012 AGM 2SS
I'm just gonna state the obvious here: maybe your going around the corner fast enough in a low enough gear that you are breaking traction on the rear tires. The most obvious answer is usually your best one. Just saying.
And btw drivers weight maybe a factor in the left and right differences as well...
Coyotekiller is offline   Reply With Quote
Old 05-10-2012, 06:23 PM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
They are the wires going into the spindles.
It's not that. The difference has to be 6% to cause a problem. At the stock tire height that is about 1.722"
Old 06-18-2012, 08:08 PM   #8
thecamaroguy
It was the difference in the tires. I put some new tires on the front and no more issues. I then put the old ones back on and issue came back. (Spare rims)
Crazy, but thank you for the pointers!!
Thanks,
thecamaroguy
