Old 02-02-2019, 01:58 PM   #1
B.mik
Drives: 2010 LLT RS
Sound after chanint timing chain
Hello guys, my trusted mechanic changed the timing chain (with tensioners and idlers)from 2 days, and wow it was a huge difference, but today i heard a sound from the engine which i think might be metal retal and its loud, what could be the problem? I talked to the mechanic and i will be bringing him the car monday, the sound wasn’t there before. No check engine light as well, he told me it might be the water pump, i forgot to tell him to change it while fixing the chain.
B.mik is offline   Reply With Quote
Old 02-03-2019, 06:50 AM   #2
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
No need to have changed the water pump when changing out the timing chains. Doubt it is the pump, however, it is an easy job.
PieNsky is offline   Reply With Quote
Old 02-03-2019, 02:04 PM   #3
B.mik
Drives: 2010 LLT RS
Thanks for the reply mate, here is a video of the sound:
https://youtu.be/P-Gql9idrn4
Is there something wrong in my newly installed chain, or is it coming from the pulleys and serpentine belt, i am scared to drive the car to him in this condition.
Old 02-05-2019, 04:58 AM   #4
B.mik
Drives: 2010 LLT RS
So it came out to be a faulty oil pump, he changed it car is pretty smooth now but the pressure on my gauge is now reaching 6-7 psi when idle on 220F ?? Am i missing something here? shouldn’t the pressure increase when changing the pump? I was getting 13 psi on idle same temp before changing the pump..
Old 03-10-2019, 08:51 AM   #5
PieNsky
PieNsky's Avatar
I watched a video where the guy said not to replace the bottom chain guide when doing the timing chains as it had something to do with the clearances on the oil pump. He said it was critical. What he suggested was to remove the nylon guide from the new bracket and switch it out with the one on the old bracket while leaving it bolted in place.
Old 03-11-2019, 10:13 AM   #6
B.mik
Drives: 2010 LLT RS
Damn... what am i supposed to do in this situation? Oil pressure is reaching like 6 PSI at warm idle.. i always worry about toasting the engine because of lack of lubircation, i was getting 13 PSI before he changed my pump.. other than that the car is running pretty smooth and no weird sounds.. could it be he messed up with the oring or some leak somewhere that reduces the pressure or a failing sensor thats leading to wrong gauge pressure ? Pfft this thing is always on my mind, i payed a ****load recently on maintenance and i don’t want to end up losing an engine.
Old 03-11-2019, 06:20 PM   #7
PieNsky
PieNsky's Avatar
Here is the video. I didn't do it exactly like this. I did have the locking cam tools on the cams that isn't shown. No way would I try to do it without them. I think he talks about the lower guide at 3:30 . All I know is I did remove mine and replaced it as I saw this video after doing the job. If I had know to remove the just the insert , I would have done that.
What does the shop that did the work think about the oil pressure?
Old 03-12-2019, 06:50 AM   #8
B.mik
Drives: 2010 LLT RS
I see, my mechanic said thats its normal since the car is on high mileage (130k) because of the tear and wear(higher clearance on bearings) and that his corvette idles at 5 psi when warm, the problem is that i didn’t face this issue until he worked on my car... yesterday i realized that the engine bay smells burnt oil, i think he messed up when installing the pump and its leaking.. i was thinking of taking it to the dealership for a check up but i will have to pay a looot or i can pay the mechanic 200$ to open it up again since he declined to check the issue since he thinks its normal... if i take it the dealership what should i tell them? I am not willing to pay 1k on this..
Old 03-12-2019, 08:11 AM   #9
B.mik
Drives: 2010 LLT RS
https://imgur.com/Sr3ZEQP
Old 03-13-2019, 07:10 PM   #10
PieNsky
PieNsky's Avatar
I think it is BS that is normal. I'll check out what my son's is at idle and will post the video for you to show the mechanic .
Old 03-15-2019, 03:03 PM   #11
B.mik
Drives: 2010 LLT RS
Thanks man i appreciate your help, do you think this will, in anyway, affect the engine? because i daily drive this thing, and i check my oil every 2 days.
Old 03-15-2019, 08:51 PM   #12
Sinister10
Sinister10's Avatar
Drives: 2010 Camaro SS
5 psi is too low...something isnt right.
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
Sinister10 is offline   Reply With Quote
Old 03-16-2019, 08:20 AM   #13
PieNsky
PieNsky's Avatar
Whoops , typo on the year
My son had just got home less than ten minutes before I shot this video. Everything is at operating temperature. Had the oil been cold , the pressure would have been higher. At start up for this video , it held 70 P.S.I. at fast idle. What does everyone else holding for their pressure at operating temperature?
Old 03-16-2019, 05:23 PM   #14
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Mine idles around 30# and regularly gets to 70# while driving.
DSX_Camaro is offline   Reply With Quote
