04-10-2024, 02:43 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Trans cooler fan wiring
I'm hooking up a stack plate trans cooler with a fan. I wired it to the main engine fan so it comes on with the fan setting in the tune. That's usually around 180ish degrees. Its a small fan. 6 inch diameter and doesn't pull that much power. Thoughts on this? Yay or Neigh?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
04-10-2024, 02:54 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Are you asking about the electrical aspect or the cooling aspect?
04-10-2024, 03:46 PM | #3 |
The electrical aspect.
04-10-2024, 04:25 PM | #4 |
I would put in a relay triggered by the main coolant fan voltage vs just pulling current directly from the main fan wiring.
04-10-2024, 05:38 PM | #5 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Agreed, ALWAYS run a load like a fan through a relay with a fused 12v source. Relays are your best friend when adding accessories.
04-10-2024, 07:33 PM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
My fan plug burned with just the stock fans running on it. I would definitely just tap into the fan feed as trigger for an additional relay with a separate power source.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-10-2024, 09:27 PM | #7 |
Ok. I have a relay that I'll wire up.
