Old 07-06-2010, 08:37 PM   #1
Hennessey Performance
Hennessey Performance's Avatar
Drives: THE EXORCIST
HPE1000 427 Twin Turbo: 1021 Rear Wheel HP Dyno Sheet
21.5 psi boost with C16 race fuel and 17 degrees of timing. No nitrous. There is still a lot of power left in this setup.
Hennessey Performance is offline   Reply With Quote
Old 07-06-2010, 10:00 PM   #2
OrangeChevyII
Drives: 2010 RS/SS2
Is it fast?
You going to bring it to the mile this year?
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block.
First to run 11's cam only
First to run 11's all motor
First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous)
First to run 10's (10.55) on motor in 2010 Camaro
First to break into the 5's (5.97) 1/8th mile
First to cut a 1.5X sixty foot
First to cut a 1.4x sixty foot
First to car to cut a 1.3x 60ft
OrangeChevyII is offline   Reply With Quote
Old 07-07-2010, 08:24 AM   #3
Jason 98 TA
Drives: Camaro
Great job guys!!!
Jason 98 TA is offline   Reply With Quote
Old 07-07-2010, 08:43 AM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Any numbers with this setup and 93 oct gas? Just wondering what the no race gas version will put out ..
thanks,
Crowley
Crowley is offline   Reply With Quote
Old 07-07-2010, 10:08 AM   #5
thanks,
Crowley
855 rw hp on 93 octane:
http://www.camaro5.com/forums/showthread.php?t=92388
Old 07-07-2010, 10:52 AM   #6
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Originally Posted by Hennessey Performance View Post
Thanks .. very stout ..
Crowley
Old 07-21-2010, 09:16 PM   #7
gtrpryde
gtrpryde's Avatar
Drives: 03 Evo 8, 93 KAT S13
Very Nice! What turbo's, turbine a.r.?
gtrpryde is offline   Reply With Quote
Old 07-21-2010, 09:18 PM   #8
Bad Azz Camaro, that will take all out.
Old 07-21-2010, 09:42 PM   #9
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
I wonder how you get traction with this much power.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 07-22-2010, 05:54 PM   #10
midgard
midgard's Avatar
Drives: red jewel camaro
Its the torque curve not going insane until after around 3000 rpms. That helps in the short time your car gets its footing.
2010 Red Jewel Camaro ss/rs
A6/L99 POWER NUMBERS....874 rwhp/880 rwtq!!
9.81@142.02
Livernois 2nd Place Car Camaro5 Fest
Original Build 13 psi/nittos.....10.44@134
3.6KB/3.5 pulley/Stock t/b..Best 9.967@142.01
SSJ3...is done....mid 9s?Rossler 6l80E Transmission
KB 3.6LC,17" Bogarts, Thanks to Hendrix 9", Thanks to Pfadt
original T/b and converter, 419ci stroker (NO LSX Block)
midgard is offline   Reply With Quote
CAMARO WIKI Tran Wiki 66 04-22-2024 11:41 AM
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 04:44 PM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 09:17 PM
STS Twin Turbo Kits Coming Soon!!! tbyrne Forced Induction 18 10-19-2009 10:06 AM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 12:06 AM
