03-30-2015, 03:23 PM | #1 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Do you inflate front tires more than rear?
Just wondering if that helps a bit with traction? I'm running my fronts at 36 psi and the rears at 35 psi. Not sure if that really helps anything or not?
03-31-2015, 09:39 AM | #2 |
Guest
That 1 PSI is not going to make a difference IMO.
03-31-2015, 10:12 AM | #3 |
Drives: 2016 Camaro SS, Garnet Red Join Date: May 2013
Lowering tire pressure only increases traction by increasing the contact patch area. The pressure would need to be lowered a lot more than 1psi to achieve that., and even if you did that it would have undesirable effects on handling due to the increased flexing of the sidewall in corners.
The best way to increase traction is to fit tires with a softer compound. |
03-31-2015, 01:34 PM | #4 | |
Drives: 2010 Camaro 1ss IOM Join Date: May 2009
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now! |
03-31-2015, 03:40 PM | #5 |
So basically just leave them all at the same pressure? I'm already about as wide as I can go, without doing some crazy track setup. Supposedly, 305 in the Michelin PSS is about as wide as some 315s. I just want the most traction I can get on the streets.
04-01-2015, 10:35 AM | #6 |
Run them all the same pressure on the street. I drop my rears to 29-30psi when I am at the track.
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie Eibach Springs & SS Sway Bars | BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph |
04-01-2015, 10:49 AM | #7 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
The lower rear tire pressure tends to improve rear tire mechanical grip, which gives you a little extra cushion against oversteer from a slightly too heavy right foot as you exit a corner. I don't think I have ever run front and rear tires on any car at the same pressure no matter what kind of car it was, nor do I think I ever would. That's part of the factory's recipe for the OE amount of understeer. I typically run the front tires 2 or 3 psi higher than sticker, with the rear tires being 1 to maybe as much as 3 under (you can justify running the rears slightly under if you rarely have adult rear seat passengers, and only for short distances when you do). This *may* be enough to notice in purely straight lines. Norm |
04-01-2015, 02:51 PM | #8 | |
04-01-2015, 03:37 PM | #9 |
For that loading condition, the only thing I can think of is that a sudden drop in temperature would be more apt to throw a TPMS warning and if you're not in the habit of periodically checking tire pressure with a gauge the TPMS lamp will light up sooner. Load capacity-wise it looks OK. On 9" wide rims, you might want to keep an eye on outside shoulder wear if you do much had cornering and air them back up a little if you notice this.
Norm |
04-01-2015, 03:43 PM | #10 | |
