03-20-2024, 03:04 AM | #1 |
Drives: 2011 Chevrolet Camaro SS A/T Join Date: Aug 2022
Rear Knuckle Bushings ?
Is there any chance to find a replacement for the rear knuckle silent blocks? Maybe smb has a part number or link ?) I found racing kit for $600 but it's more expensive than the knuckle assy...
I have a slight backlash. At first I thought it was a wheel hub bearing, but it turned out to be a bushing |
03-21-2024, 09:58 AM | #2 |
No ideas ? )
03-21-2024, 10:08 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I think that is more than a simple bushing. I think it's a rubber covered monoball so it's not likely that you will be able to replace cheaply.
03-21-2024, 10:28 AM | #4 |
It shows the bushing in the catalog but no part number or even able to buy it but for $185 a piece on rockauto I would just replace the entire knuckle, even if you find a bushing you'll have to remove the knuckle itself anyway to press out and replace it. Might not be worth all that work. That's just me though, good luck!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
03-21-2024, 10:56 PM | #5 | |
03-21-2024, 10:57 PM | #6 |
