#Camaro6
BeckyD @ James Martin Chevy
Old 01-21-2019, 07:05 AM   #1
kaamacat
Drives: 2018 ZL1/1LE Red
ZL1 - Trailer Tiedown Strap Options
Just picked up an Aluma 8220Tilt and, I am pondering the strapping options. Whatever I get will come from MACs, but, the options are basically 1) Under car frame points via ZL1 AddOn items 2) Through the wheel 3) Over tire top and secure with eTrack.
It looks like Option#1, the straps will push up against the front splitter and rear may straddle muffler area? Option#2 using MACs or any other similar will not reach the front D-Rings w/o splitter contact... may have to use side stake pockets. Positive being "X" strapping in the rear for lateral protection.Option#3 looks cleanest but, not 100% sure about lateral movement. Positive being car suspension does the work and no body/wheel contact. At this moment I am swaying towards #3 Over-The-Tire....
Thoughts, options, pics? (Thanks in advance)
BobR
2018 ZL1 1LE (Red) - New Dec 2017
2015 ViperGT (Gunmetal w/Red stripes)
2013 ZR1 Anniversary
2014 ZL1 - BrightYellow, 6sp
2011 Porsche GT3RS - White w/red graphics
2009 Porsche C2S
2001 Ferrari 360
kaamacat is offline   Reply With Quote
Old 01-21-2019, 08:17 AM   #2
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
I have option 1
I think option 1 sucks.
It compresses the suspension, which I do not like.
You can't really cross the rears, which I do not like.
The nuts on the rear like to come loose (one of these days I will put some Loctite on them).
The rear ones also spin, which they aren't supposed to, which I do not like
I want option 3
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 01-21-2019, 08:36 AM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Etrack with wheel straps and call it a day. I have pulled thousands of miles with this set up with the cruise set a 85mph and never had a strap issue or the car move any.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 01-21-2019, 09:44 AM   #4
kaamacat
Excellent and thanks. I was looking for a real-world pic and use for the e-track with our car. I also saw that Ericsson has a e-Chock that might serve as a nice addition. Again, thank you!
BobR
2009 Porsche C2S
2001 Ferrari 360
Old 01-21-2019, 10:44 AM   #5
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
Yep, that's the way!
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 01-21-2019, 12:34 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
One more for #3.
Old 01-21-2019, 12:37 PM   #7
ICTsccaCamaro
ITCRNRS
I just looked into that e-chock and called the company, it is apparently 4in tall so i'll need to double check to see if it will clear the front end. But looks very cool i'll defiantly pick up a set it they are short enough.
http://www.ericksonmfg.com/product/m...e-chock%C2%AE/
Old 01-21-2019, 04:52 PM   #8
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I use option 1 and cross the straps in the rear. Yes, the retaining nut has become loose once. The car is easy to strap and never moves so what is the big deal? Over the tire straps are likely more secure but is there any true "advantage"? I am happy towing with option 1.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 01-21-2019, 06:00 PM   #9
Slate993tt
Slate993tt's Avatar
Drives: 2018 Silver ZL1 1LE
I also Use e-track and over wheel set-up. I am super happy with it.
Slate993tt is offline   Reply With Quote
Old 01-21-2019, 06:09 PM   #10
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I have never seen E-Track on aluminum trailers. Is there a reason for that or I just haven't seen it done?
I plan to do Option 3 for the front and Option 1 for the rear.
Old 01-21-2019, 08:06 PM   #11
kaamacat
I just picked up my trailer last week, and this coming weekend will size-up where the eTrack might go (think I've measured about 61.5" avg between front and rear tire center open groove area. I would do thru-bolts on the track unless where I'd make the holes is directly over a support beam I can not access, or on the corner of a beam. We will see.
BobR
2009 Porsche C2S
2001 Ferrari 360
Old 01-22-2019, 12:50 AM   #12
ICTsccaCamaro
ITCRNRS
I am not a huge fan of pulling down on the suspension for long periods of time and I like the fact that the wheel straps only hold the wheels down and allow the suspension to still work while going down the road
Old 01-22-2019, 07:28 AM   #13
kaamacat
My same thoughts as-well. Let the car take some of the small jolts that the trailer did not absorb.
BobR
2009 Porsche C2S
2001 Ferrari 360
Old 01-22-2019, 07:44 AM   #14
2010REDSS
2010REDSS's Avatar
Congrats on the new trailer, OP!
I use Macs thru the wheels and they work fantastic. COTA is 17hrs one way, Road Atlanta is 12hrs, never a problem and the car never moves.
I cross the fronts and that allows for no contact with the splitter, and don't cross the rears as the D-rings are actually inboard the wheels a bit so the car can't move laterally.
Really simple, fast to do, and the Macs straps are the bomb.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
