09-25-2022, 06:52 PM | #1 |
Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
Remove a Spoiler
Turns out I am actually number eight on the waiting list at my local dealer and they don’t even have allocation yet, so now am back to considering lot cars out of state.
I found one I like but has the blade spoiler that I don’t personally prefer. Is it possible to remove that spoiler or would the paint be messed up underneath or would there be holes in the body/trunk? |
09-25-2022, 07:05 PM | #2 |
17’ Hyper Blue 2SS
The paint would be fine, but the blade spoiler mounting holes aren’t in the same location as an ss or zl1 type spoiler so you would either need a bodyshop to fill them, or get a new decklid.
09-25-2022, 07:20 PM | #3 |
Figured. Appreciate the info. I would actually prefer to go without a spoiler at all. (Looking at LT1 trims) would it just be the trunk that has holes or would it also be the rear of the car? The spoiler on it now extends past the trunk.
09-25-2022, 10:35 PM | #4 |
Drives: '19 M2C / '19 ZL1 Join Date: Aug 2021
09-26-2022, 04:24 AM | #5 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
The little side pieces are held by 3m tape only.
09-29-2022, 10:26 PM | #6 | |
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
10-02-2022, 06:52 AM | #7 |
Drives: 2016 Camaro 2SS "Convertibobble" Join Date: Mar 2022
Trading trunk lids would probably be the easiest, and I imagine cheapest, although I believe the true body pros on this forum would tell you that the paint technically wouldn't be ***EXACTLY*** the same, since it wasn't all painted at the same time, and that could allow for micro differences under the differing circumstances.
Am I right, true body pros on this forum? :-) Would this be enough to ruin the look? Could you even notice? Probably not, but the worry would be that, if you ever DID happen to notice, say in a certain light or from some oddball angle, well, then you might never be able to NOT see it the next time you look... Anyway, a data point of sorts: I have a convertible, and I want to remove both the stanchion spoiler and the Sirius antenna from the trunk lid, for that "boattail" look. (Functionally, to me, the idea of a stanchion spoiler on a droptop is a bit silly.) A local dealership, which did some pretty agreeable mechanical work for me a little while back, wanted $1,100 for the job. This is definitely a couple of bucks but would, at any rate, hopefully assure that any broken parts (or other randoms) could be repaired easily and quickly with readily available OEM stuff. Next, a deep check at a very reputable body shop said they could do it for something in the mid-$700 range. Even better! Keep in mind that this is in Knoxville, TN, so your NY/LI prices would probs be higher. OTOH, I was also talking about the Sirius antenna, not just the trunk spoiler, so that's fewer holes and maybe fewer bucks. Keep us posted here or shoot me a PM with your results!
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp) '99 4Runner 367K '94 ST1100 146K |
