Old 05-19-2024, 06:44 PM   #1
Teeth
Teeth's Avatar
Drives: 2010 Chevrolet Camaro SS
Cammed SS running hot?
2010 Camaro SS running at 217 when idling in city, this sound normal? I have a 160 stat, tuned fans to come on early, installed Mishimoto radiator, still getting high temps. Goes down when moving and getting air over the rad, but just worrier about the engine.
2010 Camaro 2SS/RS:
Cyber gray matte wrap, Danti Lambo style louvers, Granatelli Pro-stock look wing
B&M transcooler, Mishimoto oil cooler, Mishimoto catchcan, Borla/Pypebomb axle back
L99 to LS3 conversion, Vararam ram air intake, BTR Nightfury cam, Johnson lifters, LS7 injectors, Circle D 3200 stall converter, Kooks LT headers, Custom X-pipe
Teeth is offline   Reply With Quote
Old 05-19-2024, 07:43 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
You're good. Mine hits 210 on avg. even on highway. Just use good oil. If you're really worried you can have the fans turn on sooner/longer.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-19-2024, 08:01 PM   #3
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I think your fine too. I have similar mods too & the 3200 might be a bit tight in traffic. You can always try burping it again incase there is an air pocket.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
acutron42 is offline   Reply With Quote
Old 05-19-2024, 08:44 PM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Originally Posted by acutron42 View Post
I think your fine too. I have similar mods too & the 3200 might be a bit tight in traffic. You can always try burping it again in case there is an air pocket.
This, I had a bubble in my system while running at Indy, temps would spike like crazy and then come right back down.... Many experts claim the engine should run between 195 and 220 degrees F.
Old 05-19-2024, 10:12 PM   #5
Teeth
Teeth's Avatar
Thanks fellas, got me worried since I just got the head gasket replaced. Everything is making me anxious about the car now haha
2010 Camaro 2SS/RS:
Old 05-21-2024, 07:17 AM   #6
RupertPupkin
Welcome to the mod game. Since my engine blew, I constantly check for noises, temps, pressure, etc etc.
730whp: 630Trq
Old 05-21-2024, 02:13 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
You aren't in any danger, temp wise. But its definitely higher than mine runs in Florida with a 160º stat and cammed/tuned engine and earlier fan activation.
I typically won't hit over 200º very often. I cruise in the 175-185º range, and normally idle between 192-200º. I tend to think mine runs a bit cooler than it should, but I have seen others with same/similar mods running the same temps. Most likely culprit is an air pocket, as these cooling systems can be a bit of a pain to properly purge.
Old 05-21-2024, 03:41 PM   #8
acutron42
acutron42's Avatar
InFiD3ViL, I went to a cars & coffee event Sunday & was right in your range. 13 miles each way, 75 degrees with a lot of stop & go. I am not concerned but you don't want them too cool either.
Old 05-21-2024, 08:52 PM   #9
rdavis
Drives: 2012 SS
I run a 180 stat & fans on at 207 & off at 195. Never goes over 208. My car seems to run its best at about 190-195.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
rdavis is offline   Reply With Quote
