11-12-2022, 10:06 PM | #1 |
Drives: 2023 Camaro 2SS 1LE Join Date: Sep 2015
Easy Entry Memory Issues
Hi Guys, I can't get the easy entry to work correctly. Exit works fine but when I start the car the seat won't return to the memory setting, I have to hold the button any fix for this?
11-13-2022, 08:30 AM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
The seat will auto-adjust when you start the engine or enter service mode.
This applies to the 6th gen, if you indeed have a 2015, I'm not sure it works the same way.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
11-13-2022, 10:35 AM | #3 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
Plus, on the sixth gen at least, there are two settings - one for entry memory and one for exit memory. It could be that the entry memory got toggled off?
11-13-2022, 10:36 AM | #4 |
I just purchased a 2023 1LE need to update my info
11-13-2022, 10:39 AM | #5 | |
Both Exit and Entry are toggled on. I can't figure it out driving me insane https://ibb.co/zVLTGbP |
11-13-2022, 10:41 AM | #6 |
11-13-2022, 11:07 AM | #7 |
If it is a manual trans the EPB must be set!
11-13-2022, 11:17 AM | #8 |
11-13-2022, 11:20 AM | #9 |
11-13-2022, 12:33 PM | #10 |
11-13-2022, 03:25 PM | #11 |
The way this is supposed to work when easy entry/exit options (named "auto memory recall" and "easy exit recall" in my 2018 infotainment) are enabled is that depending on which fob you have on you, the seat moves to the #1 or #2 saved position as soon as you start the engine.
This will not happen if you have and use fob #3 (or higher), or if you did not save a position for the fob you are using, or if the transmission is not in Park (which is very unlikely). Also, if you have two or more fobs on you, the seat will move to the most recently used position, that is, the one associated with the single fob you used last. What I would do at this point is disconnect the battery for a night, reconnect it, re-save the positions including the exit position, then make sure the auto recall settings are correct, then try this again. If it still doesn't work, I'd take the car in.
11-13-2022, 05:07 PM | #12 |
+1, arpad_m hit the nail on the head!
11-13-2022, 07:17 PM | #13 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
If you don't have the parking brake set when you start the car again auto memory will not work you will have to manually hit the button. So set the parking brake every time you exit.
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
11-14-2022, 08:09 AM | #14 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
There are 3 settings. Entry 1 Entry 2 Exit Position To Set: Adjust the seat where you like: Press Set then hold Entry 1 wait for the double beep. Rinse and repeat for Entry 2, and Exit positions Make sure the car is running when you set Entry 1, 2, and Exit positions After setting: Turn the car off. Car should automatically go to exit position. Now Turn the car back on: Car should automatically go to Entry Position 1 Lastly, Check your in car settings on the Touch Screen, and make sure memory seat function is enabled. There is also a setting for mirrors as well. This is also not required for Automatics.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LS MSD Plug Wire Set | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq
