09-18-2013, 07:02 PM | #1 |
Drives: 2012 Camaro 2SS/RS 45th Anniv Edt Join Date: Aug 2012
Items for sale......
I'm getting ready to trade-in my 45th Anniversary 6MT. So I figured I would take it back to stock before I get rid of it. Wife and I had a baby and car just doesn't fit the new life style and traveling that we do. So here is the list of parts (All parts have about 2K miles on them): 25% Under drive Pulley - $125 shipped Thanks for looking................... Last edited by SirCrush32; 01-16-2014 at 12:30 PM. Reason: update list |
09-18-2013, 07:47 PM | #2 |
Echale Gas [COTW 3/10/14]
Drives: 2010 Camaro SS/RS Supercharged Join Date: Aug 2010
Whats brand on rotors and is that for all 4?
Kenne Bell 502 rwhp/ 471 rwtq at 9psi (daily driver...for now) Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers |
09-18-2013, 07:52 PM | #3 |
Master Amateur Mechanic
Drives: Victory Red 2011 2SS/RS Join Date: Jan 2013
Would you do 90 on the breaklines?
09-18-2013, 07:55 PM | #4 |
I wanna go fast!!!!
Drives: 2010 SS/RS Inferno Orange Metallic Join Date: Dec 2010
I am also interested in the rotors...what is the brand and do you have any pics?
Proud Member Dayton Camaro Club (DCC) http://www.camaro5.com/forums/group.php?groupid=412
And on Facebook https://www.facebook.com/groups/DaytonCamaroClub/ |
09-18-2013, 08:13 PM | #5 |
Drives: 2014 Camaro SS Join Date: Sep 2013
Post pictures please!
09-18-2013, 08:43 PM | #6 |
what brand is the cold air intake? please let me know.
09-18-2013, 09:45 PM | #7 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
What CC chambers are the heads milled too?
2010 Camaro SS LS3 - No Modz
09-19-2013, 07:37 AM | #8 |
I got this right off TSP site. I hope this helps.
All Precision Race Components (PRC) cylinder heads come fully CNC-ported and machined using state-of-the-art technology! Click Here to SEE why we build better heads! PRC's aftermarket casting LS3/L92/L99 cylinder heads come standard with the following options: NEW PRC 13-Degree Valve Angle LS3 Castings Improved Piston-to-Valve Clearance For Extra Compression & Larger Camshafts Smaller Than Stock Intake Port Volume For Improved Port Velocity Manley Stainless 2.165" Intake, 1.60" Exhaust Valves Your Choice of Spring Kit Completely Assembled and Milled to Your Specifications 60-68cc Chambers All PRC cylinder heads are extensively researched and tested. The all-new PRC aftermarket casting LS3 cylinder heads are designed to flow like a ported casting while keeping the port sizes smaller for improved port velocity. The result is a cylinder head that is over 10cc's smaller than a stock GM LS3 port and moves more air than a ported GM casting! These heads show dyno-proven 40+HP gains over stock 6.2L cylinder heads! The flow data below shows the superior performance of the PRC LS3 and L92 cylinder heads! The all new PRC aftermarket casting LS3 heads are the perfect option for stock cube LS3/L99 & L92 engines looking for the most powerful LS3-style cylinder heads that we offer. Engine dyno testing has shown big power gains across the entire RPM band compared to even the best ported stock GM castings that we have tested! The 13-degree valve angle will allow for the ability to run more compression and larger camshafts thanks to an additional .040" better piston-to-valve clearance!! Lift Intake Flow Exhaust Flow .200" 154 cfm 117 cfm .300" 221 cfm 170 cfm .400" 281 cfm 205 cfm .500" 325 cfm 225 cfm .600" 354 cfm 235 cfm .650" 358 cfm 240 cfm .700" 361 cfm 243 cfm |
09-19-2013, 07:38 AM | #9 |
09-19-2013, 07:39 AM | #10 |
09-19-2013, 07:48 AM | #11 |
09-19-2013, 10:24 AM | #12 |
Drives: 2013 Camaro 1SS/1LE Join Date: Feb 2013
Willing to sell just Headers? does it have catted connection pipes or catless?
09-19-2013, 12:13 PM | #13 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
definitely like some pics if u can!
09-19-2013, 02:04 PM | #14 |
Drives: 2013 1LE camaro Join Date: Apr 2013
Interested in the cam! Mileage? Also interested in the rotors! Is that for all four?
If you're reading this objects In side view mirrors are losing as I'm rowing the 3:91's |
