Old 02-20-2024, 02:21 AM   #1
805_LSTRES
805_LSTRES's Avatar
Drives: 2014 SS Camaro
Procharger install
I’m in the process of installing my procharger kit that I’ve been piecing together.
Have a few questions about the modified harmonic balancer.
1. Does the new balancer require a seal ? In the instructions it says to make sure there is a seal.
2. Does the new crank bolt require a cupped washer ? Per the instructions as well.
Thanks
2014 SS Camaro M6 ,D1sc Procharger 9lbs, Long tube headers , squash dual 450s E85, Tuned by New Era Performance. 611hp
805_LSTRES is offline   Reply With Quote
Old 02-20-2024, 01:46 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks
Seal and bolt should be replaced we stock them both www.jannettyracing.com
Ted.
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-20-2024, 03:25 PM   #3
805_LSTRES
805_LSTRES's Avatar
Ted.
Hey Ted , I have a new bolt already just not sure on the “cupped washer “part for the crank bolt. and not sure which seal I need for the harmonic balancer. Is it the friction washer they are referring to in the instructions ? Thanks
