#Camaro6
Old 09-02-2016, 11:05 PM   #1
Razzaa
Razzaa's Avatar
Drives: 2016 Camaro 2SS
Key fobs stopped working!!!
All of a sudden both of my key fobs don't work at all. I can't drive my car or pop the trunk or anything else. Anyone run into this before?
Razzaa is offline   Reply With Quote
Old 09-03-2016, 01:09 AM   #2
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
I haven't seen this yet. Sounds like you need to ring the dealer to come pick the car up and fix it.
I am assuming the link between your car and fobs got reset for something?
Sledgehammer70 is offline   Reply With Quote
Old 09-03-2016, 03:13 AM   #3
Razzaa
Razzaa's Avatar
I can unlock the car with the onstar app. If I place the fob in the back cup holder, it will allow me to start the car. The fob won't do anything else though.
Old 09-03-2016, 03:34 AM   #4
nvrsatisfied
nvrsatisfied's Avatar
Drives: 2016 SS
In your first post you stated you can't drive it, Second post states you can start it with fob in car. If it starts, why can't you drive it?
1SS Summit White Coupe MRC NPP A8
Ordered 1/12/16
TPW 2/15/16
nvrsatisfied is offline   Reply With Quote
Old 09-03-2016, 06:37 AM   #5
jasonsk287
jasonsk287's Avatar
Drives: 2012 Camaro 1LT
Maybe they need to be reprogrammed for some reason?
2012 Camaro 1LT
Summit White/Black Rally Stripes
Ordered 8/21/11, built 9/22/11, delivered 10/7/11
jasonsk287 is offline   Reply With Quote
Old 09-03-2016, 07:07 AM   #6
jeverton
jeverton's Avatar
Drives: 2017 Camaro 50th Anniversary 2SS
Maybe the battery in the key fob is dead? Replace with a CR2032 or equivalent battery.
Owners manual - page 34... If the transmitter battery is weak or if there is interference with the signal, the DIC may display NO REMOTE DETECTED or NO REMOTE KEY WAS DETECTED PLACE KEY IN TRANSMITTER POCKET THEN START YOUR VEHICLE. See Key and Lock Messages page 138.
50th Anniversary Edition 2SS, NFG, BLACK, M6, MRC, NPP, BLACK BOWTIES
Build Date: July 21, 2016
Production Sequence: 934
jeverton is offline   Reply With Quote
Old 09-03-2016, 08:43 AM   #7
MovieGuy
MovieGuy's Avatar
Drives: 2016 Camaro 1LT
Did the battery die in both of his fobs simultaneously?
http://www.camaro6.com/forums/image.php?u=115947&type=sigpic&dateline=1461721697
Life after retirement
MovieGuy is offline   Reply With Quote
Old 09-03-2016, 08:44 AM   #8
MovieGuy
MovieGuy's Avatar
Looking at the posts being 4 hours apart, I am guessing he played around with it some after posting and discovered he could drive it.
Old 09-03-2016, 09:55 AM   #9
Razzaa
Razzaa's Avatar
Yup. I discovered it could start with the fob in the cup holder.
Old 09-03-2016, 09:58 AM   #10
Razzaa
Razzaa's Avatar
Exactly. My second fob is my backup and has only been used a couple times by my wife. I'm thinking the transmitter in the car that picks up the fob signal is done.
Old 09-03-2016, 11:43 AM   #11
MovieGuy
MovieGuy's Avatar
At least you can get it to the dealership under it's own power
Old 09-03-2016, 01:42 PM   #12
Razzaa
Razzaa's Avatar
All of a sudden my TPMS failed and than started working 5 minutes later. Also both my fobs work now. I scheduled an appointment with service for Tuesday. Something is acting up, that's for sure.
Old 09-03-2016, 02:13 PM   #13
mcsoul
Drives: Want a gen 6
Sounds like your computer or I2C (or whatever they call the com bus) bus is hosed.
mcsoul is offline   Reply With Quote
Old 10-06-2016, 08:53 PM   #14
BCKTLST
Drives: 2017
Well here we go. Same thing happened to me tonight. Parked car and went to shut if off and got an error message on the screen that said..No Remote detected. Thought it was odd, got out of the car and went to lock it and NOTHING. Wife went and got hers and still nothing. Put it in cup holder and it started.
We have only had this 2017 Camaro 50th SS2 for less than 2 months and have already had to have it towed in for a a new starter after only 3 weeks. Now having this remote issue.
This is our first Chevrolet in many years and I am remembering why!
BCKTLST is offline   Reply With Quote
