02-07-2018, 12:45 AM | #1 |
okcamaros.com
System install $ ?’s
I’m looking to replace my entire factory speaker system on my current factory Bose system. I was looking into JL because my brother owns an audio shop and he apparently gets a great deal through JL. I don’t need the best system, but I’d like to get a good one.
Any recommendations on speaker/amp/tweeter combos? Any input would be helpful
In Oklahoma? Have a Camaro?! Join OkCamaro's on facebook!
Blake https://www.facebook.com/groups/okcamaros/ |
02-07-2018, 01:27 AM | #2 |
Drives: 2018 Camaro 1SS Join Date: Jul 2017
i did mine with all different components, pick what u like then sort out prices. i ordered mine all thru crutchfeild, there awsome when it comes to warrenty and returns. prices are good too.
02-07-2018, 01:29 AM | #3 |
i kept front dash speakers stock and also kept rear quarter panel speakers stock. added 6x9 to rear deck and moved tweeters to B piller and adoors
02-07-2018, 01:30 AM | #4 |
hope this helps
02-07-2018, 01:54 AM | #5 |
okcamaros.com
This is rather unique. I quite like this. My sub and it’s supporting amp is coming from audiofrog (I got a unique deal from the owner). Rest of the speakers will be JL or whatever.
I appreciate everyone’s feedback
02-07-2018, 01:04 PM | #6 | |
Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
To the OP, there are tons of options out there, even with JL audio. As an audiophile, my audio builds are extreme. So imaging, time alignment, etc are really important to me. If you are going with JL audio, and do not plan to use a signal processor, then you have your choice of setups. For a moderate budget setup, staying with JL audio, I would go with : Drivers: C3650 component setup for the front stage. tweeter in the dash, replace 6x9 with 6.5 in the door. C1650x to replace rear side panel speakers C290Cx for rear deck (not necessary if you are adding woofers) Subwoofers: If adding subwoofers, I would forego the rear deck speakers, and add single or dual JL W6v3 woofers in a sealed box. Amplifiers: + rear deck speakers: 4 channel + 4 channel (with two channels bridged to power the woofers, and other two to run the rear deck drivers) - rear deck speakers: 4 channel + 1 channel mono for the sub, or 5 channel amp The problem with our cars is maintaining functionality of all door chimes, warning signals, etc. Some setups do not allow for retention of these without unplugging door microphones. The GM650 by NavTV allows for seamless integration of the OEM headunit with all aftermarket setups, with or without use of a signal processor. This is about as basic of a setup that I can suggest. Which drivers , amps, and subs really depends on your budget. If you want suggestions on signal processors (or an explanation on why you want them) let me know. hope this helps.
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK |
02-08-2018, 06:29 PM | #7 |
Banned
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Don't you have highs blasting straight into your and your passengers ears all the time?
That can't sound right |
02-08-2018, 10:35 PM | #8 |
passengers lol no one fits in the back of these things. i like highs, i have it tuned pretty well. im not 18 where u just want a shit ton of bass, i like to hear what my wilson phillips CD has to offer Jk but for real i think its a great combo
02-10-2018, 02:58 PM | #9 | |
@James, there is no way you have this tuned well. You may have it how you like it, but no way it’s tuned correctly. The tweeters in the A pillars aren’t so much the issue as is the tweeters in the B Pillars. There is nothing that you gain from that. If the B-pillars are passively crossed with the rear drivers, then you have high frequency signals from rear channels hitting your ears at the same time as the high frequency sounds from the passively crossed over front stage. If you are actively crossing over the tweets, then you could dial back the high Frequencies through individual channel adjustments. And you could set a lower crossover threshold to maybe pick up some more vocals. If you are running these with a passive crossover, then they are likely crossed over pretty high, out of the range of most vocals, and only adding more sizzle to the top end. Either way, the staging with this type of setup is impossible to tune correctly, even with a DSP and DTA. But, if you like it, that’s all that matters!
02-11-2018, 08:59 PM | #10 |
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
Best advise I can give is buy things here and there and wait till you have everything. I would suggest a decent set of front components, 5 channel amplifier, subwoofer and JL Audio FIX 86. The FIX86 really cleans up the sound. By buying a 5 channel amp you would save some money.
02-11-2018, 09:01 PM | #11 |
front and rear speakers $250
subwwofer with box $300-$500 Amplifier $250 kenwood 5 channels really good JL Audio FIX 86 sound processor $400 you do the math. |
02-24-2018, 08:29 PM | #12 | |
Drives: 2004 Corvette / 2017 2SS Camaro Join Date: May 2016
Upgrading stock Bose sound
I saw your recommendations below for a basic setup and I am interested in getting a good quality sound with adequate base and wanted to get your opinion on a good JL audio setup with and without subwoofers. (I want to keep all the factory chimes, etc.)
Thanks in advance Quote:
02-25-2018, 12:35 AM | #13 | |
Some guys do a hack job on the factory wires, or splice into wires. If you get the M650 piece from NavTV you don have to do any of that, but that piece alone is $850
