Old 12-04-2020, 05:04 AM   #15
jimmyp
Drives: 2013 Camaro Convertible
Last Question. Anyone know if there's a difference between the back half of an SS manual driveshaft or an Automatic? Not Sure if they're different lengths?
jimmyp is offline   Reply With Quote
Old 12-04-2020, 06:11 AM   #16
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Driveshafts are different lengths but I can't tell you for sure if it's the front of rear part of the shaft.
Sent from my Pixel XL using Tapatalk
Old 12-04-2020, 06:54 PM   #17
Pearlj10
Drives: 2011 Camaro 2LT
The length of the rear shaft is different, as is the bolt up pattern.
Pearlj10 is offline   Reply With Quote
Old 07-22-2023, 08:48 PM   #18
Ck1984
Drives: 2015 camaro LFX V6
SO to do this swap you just need the
1. used or new center pumpking with LSD in it and hopelly much faster gears than stock V6 rearend but also both corresponding
2. new /used axles to go with new pumpkin.
the old brake calipers, rotors etc bolt right up?
3. the front 1/2 old driveshaft works too maybe with different back 1/2? i wonder how much most wreckers would charge for just back 1/2 of driveshaft versus a new aluminum driveshaft that sposed to reduce rotating mass a fair bit?
plus new gear oil n additive and that is complete parts list?
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
