Old 11-09-2015, 08:36 AM   #1
Vicster
Vicster's Avatar
Drives: 13' ZL1
Question ENGINE ISSUES AFTER TUNE: NEED HELP
H
Vicster is offline   Reply With Quote
Old 11-09-2015, 08:45 AM   #2
Hocky
Drives: Cts-v2
Your open loop stumbling is because your tune is way off with wrong AFRs and it won't run right until the fuel trims are there to "fix" it. The rpm hang is probably related to idle airflow tuning. Either way, both are major failures on the tuner's end.
Hocky is offline   Reply With Quote
Old 11-09-2015, 08:47 AM   #3
vicnkathy
Drives: 2014 Subaru Forester Turbo
Find another tuner asap. Those are both amateur mistakes..
vicnkathy is offline   Reply With Quote
Old 11-09-2015, 09:34 AM   #4
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
Is the car stock? Or what's done to it?.. If you haven't added a cam you shouldn't have any of these problems... Even with a cam I think a good tuner would have still addressed these problems
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 11-09-2015, 10:19 AM   #5
Vicster
Vicster's Avatar
Drives: 13' ZL1
Thank You for your input!!
Old 11-09-2015, 10:48 AM   #6
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
Give Tom Wong a call in Vancouver, he will dial it in for you.
http://www.wongsperformance.com/index.html
owhite3003 is offline   Reply With Quote
Old 11-09-2015, 11:04 AM   #7
Vicster
Vicster's Avatar
Drives: 13' ZL1
This is my tuner
This is my tuner...
Old 11-09-2015, 11:16 AM   #8
owhite3003
Z-BEAST
owhite3003's Avatar
Tom is usually spot on, my Z will stumble for a brief second when just starting out cold and I didn't use Tom. Let us know what you find out.
Old 11-09-2015, 11:37 AM   #9
DrkPhx
DrkPhx's Avatar
I'm sure there's a cam and bigger TB in the list, but can you list your mods?
Old 11-09-2015, 02:08 PM   #10
DrkPhx
DrkPhx's Avatar
Now that's a mod list. Well done. Assuming your cam has a wide LSA with low or negative overlap that should be relatively easy to dial in along with a 90mm TB. As mentioned above the cold start stumble is in open loop which uses the VVE table. It just takes time to dial it in because the engine temp rises so quickly on start up. The second issue is more concerning especially the surging. Since you already paid him to tune, I would bring it back with the specifics you listed here and ask him to iron it out.
Old 11-09-2015, 02:43 PM   #11
DrkPhx
DrkPhx's Avatar
I like the specs. -5 overlap is considered mild for this motor. Those are good lobes for this application. Should have a nice and quiet valve train. The second issue could be a couple of factors depending on exactly when and where it occurs. Assuming the fueling is correct, it could be spark timing through a few tables along with the idle airflow table noted above. When you bring it back ask him to datalog while you drive the car so you can point out the problem areas. Hopefully he allows that and it will help a lot.
Old 11-09-2015, 03:17 PM   #12
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
Has the car been on the dyno or remotely tuned? If remote, then data log it and send your tuner the data logs. If he still does not correct the situation then I would suggest using one of the reputable tuners on this forum. They can do a great job remotely by just exchanging logs.
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 11-09-2015, 03:17 PM   #13
Vicster
Vicster's Avatar
Drives: 13' ZL1
Talking
I am trying to set up a saturday appt. so I can drop the car off friday night, it should be nice and cold in the morning. Data logging during a drive is a great idea. He should be able to see exacty what is causing the rpm to jump up.
Thank you, Victor
Old 11-09-2015, 04:03 PM   #14
DrkPhx
DrkPhx's Avatar
^^^ Surprised there was no street tuning done with a cammed car.
