07-07-2013, 09:47 AM | #1 |
I like teeth.
Drives: #198 Join Date: Oct 2009
Bouncer's Capture The Rapture - Just Half A Test Episode 4
This video series is all about testing the beading and sheeting properties of different LSPs and bringing the results to you.
Video in link, hope you enjoy!! http://youtu.be/obWSKyVlGbU
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." Last edited by ihaveacamaro; 07-07-2013 at 08:33 PM. |
07-07-2013, 09:51 AM | #2 |
Drives: 2012 AGM SS Join Date: Jun 2012
Looks good. I've been looking at Sherbet Fizz. Eventually you need to put together a ranking with a point system with all these waxes
07-07-2013, 10:08 AM | #3 | |
I like teeth.
A point ranking is actually a very very good idea! I'll definitely do that, thanks for the suggestion
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
07-07-2013, 10:09 AM | #4 |
Drives: ... Join Date: Apr 2009
Nice video. The cool thing is bouncers are homebrew wax, all handmade and hand poured by Jay. I just found that it is very oily, although it spreads great.
07-07-2013, 10:10 AM | #5 | |
I like teeth.
I found removal actually quite difficult since it seemed to spread rather than remove. I'm going to try making it an even thinner application next time and see if that helps
07-07-2013, 10:14 AM | #6 |
I like teeth.
just realized the editing mistake I made regarding sound... working to fix it now.
07-07-2013, 12:05 PM | #7 | ||
But can't wait to see sherbet fizz thanks again!
07-07-2013, 12:12 PM | #8 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
I want to try that wax out so bad !
I hear it has more gloss enhancing properties. Is that true?
07-07-2013, 08:27 PM | #9 |
I like teeth.
07-07-2013, 08:31 PM | #10 | ||
I like teeth.
I was going to do an actual scoring on the beading and sheeting: 1) Fuzion: Beading 8 Sheeting 3 2) BlackICE: Beading 8.5 Sheeting 9.5 3) Adam's: Beading 8.5 Sheeting 8.5 4) Capture The Rapture: Beading 9.5 Sheeting 9 Quote:
FWIW: I couldn't tell a difference with the other waxes either.
07-07-2013, 08:50 PM | #11 | |
Glad you reviewed it.
07-07-2013, 08:56 PM | #12 | |
I like teeth.
Idk, I just see such little difference on a polished panel. Now, don't get me wrong, I'm not saying there isn't a difference like the Junkman says, just that I can't see it. I'm sure if you used a gloss-o-meter, you could tell. Or maybe someone with better eyes.
07-07-2013, 09:05 PM | #13 | |
About the only time I notice a more glossy/shiny surface is when a sealant is applied. Did you buy the full pot or get a sample ?
07-07-2013, 09:20 PM | #14 |
I like teeth.
A really small sample. I didn't want a beauty wax, but did want to test it out for JHAT
