07-08-2013, 12:35 PM | #1 |
Drives: 2010 SS Join Date: Aug 2006
What a beginner needs in their arsenal....
I'm going to list your basic supplies and tools needed, for most guys/gals this will be all they really need...again, these are the basics.
1. PC or the Griot’s Garage 6 Inch Random Orbital Polisher, what I've learned is you can get the Griot's with a 25" cord which I would recommend. 2. Maguire's Gold Detail Spray with Clay Bars. 3. Maguire's Gold Class Wash Shampoo. 4. Meguiar's Scratch X 2.0, I recommend this because it's a mild compound for the beginner. 5. A couple of each orange pads and red pads, best from either CG or Adams. 6. Two five gallon buckets ( new if possible ), get two Grit Guard Inserts....CG, Adams will be fine.....two bucket wash of course. 7. Meguire's NXT Generation® Tech Wax® 2.0 - Liquid. 8.Turtle Platinum Wheel Cleaner, Turtle Platinum Tire Dressing....don't forget the curved tire dressing sponge. 9. Now comes polishing micro fiber towels, Premium Microfiber Towels would be your best choice. I've never seen a good micro towels locally so I would suggest getting the from CG, Adams or Groit's. 16"x16". 16"x24". Four of each should be a good start, when ordering get a couple of three or four 26"x35" Waffle Weave Microfiber Drying Towels. 10. A couple of detailing brushes are useful. 11. Two Micro Fiber Washing Mitts, one for the upper part of the car and the other for lower section ( belt line ) of the car. A couple of things you've probably noticed, to make it less confusing I've suggested some over the counter products for the beginner. BTW, I've used these products and they have work very well for me. I may have missed something here but I think these items should work just fine for many members here, what you want to do is make the right choices the first time so you're not wasting your money....there's too many flavor of the month products out there so be wise.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
07-08-2013, 12:49 PM | #2 |
Good post, thanks for taking the time to put it together. I really like a lot of what you have there.
Couple questions/suggestions that came to mind as I read this: -ScratchX- not really the best choice for a machine application. It doesn't like heat. -No polish to clarify after? -Why orange and red? Orange and white is a much more common choice. Red generally has no cut, is very soft, and is for application of LSPs. -What's the rationale of having four each of 16x16 and 16x24? I generally find these sizes to be interchangeable. -What do you like about the TW products you have listed? I've never tried them so I'd like to hear more about them. One thing I would suggest is that you can often end up spending way more in the long run on cheap OTC products because you have to use more of them and more often. Sure, $40 for a bottle of tire and trim coating is tough to swallow up front, but when one application lasts 3+ months as opposed to a couple weeks for the OTC stuff, you profit a ton over time. This is why I always suggest people get started with quality products from the get-go. You save money and you eliminate, or greatly reduce, the risk of getting unsatisfactory results and throwing in the towel on detailing altogether. Hope that doesn't come across as rude, I am just genuinely curious on those questions and offering an alternate opinion.
[B]
07-08-2013, 01:20 PM | #3 | ||
-AS for polish Meguire's NXT Generation® Tech Wax® 2.0 - Liquid should meet most owners needs. -Orange and the Red pads again work for me, the worst thing a beginner can do is have pads that are heavy on cutting....that's not for me. -I just like to have different sizes towels available. -I've tried other tire and wheel products and found these work great for me. I think what can turn people off is getting bombarded with too many suggestions on what's best and what's not. Just saying Quote:
Later, Al
07-08-2013, 01:21 PM | #4 |
Drives: Love the one you're with Join Date: Sep 2009
You missed the most important thing you need in your arsenal. That's a really large check book.
07-08-2013, 01:30 PM | #5 | |
I say that because I've decided I just gotta have the Groit's 3" polisher to go with my other polisher's, I mean, I just gotta have it.
07-08-2013, 01:30 PM | #6 |
Drives: ... Join Date: Apr 2009
07-08-2013, 01:38 PM | #7 |
Drives: 2012 Camaro 2SS/RS IOM Join Date: Oct 2012
As a newb, I would suggest lots of towels. I have 3 zaino towels and I ended up washing them 3 times during my detailing. I used them to dry the car after washing, dry the car after claying (rinsing) and then at least 1 more time during polishing and final wash when I was done.
07-08-2013, 01:47 PM | #8 | |
07-08-2013, 01:50 PM | #9 |
Just to clarify, Tech wax is in no way, shape or form a polish...
[B]
07-08-2013, 01:55 PM | #10 |
Is that because it called a wax?
07-08-2013, 01:57 PM | #11 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
I understand offering OTC products but since he's already going to have to order a DA, pads, and MF towels, it only seems logical that he/she should order some good products while they're at it. I agree with CD about the scratch X. Wasn't impressed with it when I used it. IMO, Meguiars Ultimate compound and Ultimate polish would be a better choice for the beginner and both are easily found at local stores. Orange pads are pretty much standard compound pads for most that aren't using the MF pads. If you look at the progression chart, white is right below it and is recommended for polishing. Red is at the very bottom and is generally used for application of LSP's and sealants. As has been said, it has no cutting ability so it's not really doing much. Using a better cutting pad for polishing would make the job go a lot quicker. I would also add in a healthy supply of detail spray. Pretty much all of them work well but ONR is undoubtedly the best bang for the buck and has multiple uses, depending on how you dilute it. It's one of the products that should be ordered when you get your online stuff.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
07-08-2013, 02:38 PM | #12 | |
I believe Meguiar's Ultimate Compound is more abrasive then Meguiar's Scratch X 2.0, using abrasive compounds and pads results in thinner clear coat......you could end up with a split coat if you're not careful.....then again, if you do those micro fiber polishing towels will work great as a crying towel.
07-08-2013, 02:59 PM | #13 | |
Search Ninja
07-08-2013, 03:18 PM | #14 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
What is this CG you are talking about getting supplies from?
