04-13-2015, 03:24 AM | #1 |
Drives: 2013 1LT Join Date: Jan 2015
Removing stubborn bugs?
I've been battling large amounts of bugs on my evening and morning drives. One week with my at least 50 hour work week schedule doesn't leave much time on weekends either. So my questions is can any one recommend a good actually the perfect big remover that would "eat away" the dead remanents without harming the clear coat? Wax isn't an issue cause I wash and de wax and re wax every few weeks to keep it fresh (I use cheap wax for short term application) it's also very dirty so a "car wash" with my soap would remove the wax any ways so it doesn't help too much using a more expensive long term wax. Anyhow is there any product that people would recommend I could use? I currently use bug and tar remover from turtle wax but it leaves a VERY greasy film afterwards and the stuff doesn't move them without heavy elbow grease which leaves me worried of scratching the clear coat. Any product recommendations would be fantastic thank you.
04-13-2015, 07:38 AM | #2 | |
I like teeth.
Drives: #198 Join Date: Oct 2009
use a sealant like blackfire wet diamond. It's better at protecting your surface than waxes are. More durable too.
And then the easiest thing to do is take 2 minutes out of your time at the end of the day to wipe away FRESHLY hit bugs with a waterless wash. They'll come off super easy and you won't have to worry about any left over film from a bug and tar remover! If you wait the entire week, they will be dried on and you will have to use your bug and tar remover.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
04-14-2015, 07:03 PM | #3 |
So would I wash, clay, and spot treat light surface scratches, then just use that product as my "wax" persay? And after its applied should I put a wax over it to make it more aero dynamic? I have dogs and nieces and nephews that love to try and put hands/paws on the car and I need a slick coat in it to avoid scartches hence the wax I use is cheap cause I wash it almost every other weekend and the soap I use strips off the dirt and undortantely the wax as well, just not bugs and tar xD
04-14-2015, 08:26 PM | #4 |
I'm probably going to get some backlash from this but...I have found that the best thing to remove bugs from my vehicles is a dryer sheet. I simply wet the vehicle where the bugs are and wipe them off with the dryer sheet. Once the dryer sheet loses all of the fabric softener simply get a new one. I usually have the hose running at the same time as to not leave the fabric softener on the paint. Between waxes I make sure to hit the area with some detailing spray after I dry it. I used it on my black 2007 Z06 from the day I got it to the time I sold it four years later...no noticeable issues with the paint.
2015 Camaro ZL1 (#1090)
04-14-2015, 08:29 PM | #5 |
I like teeth.
Yes, you want to use the sealant instead of the wax. You can add wax over the sealant if you wish, but the Blackfire Wet Diamond Sealant is top notch quality and you don't want to put a not so good wax on top. It's like dressing a hot model in clothes you found from your grandmother's closet.
So in your case, I would recommend the sealant on its own. And soap won't take this sealant off.
04-14-2015, 08:30 PM | #6 | |
I like teeth.
04-14-2015, 09:06 PM | #7 | |
Drives: 14 1SS Camaro 1LE, NPP, Recaros Join Date: Nov 2013
Bugs dissolve in seconds, rubber marks from track come right off. |
04-14-2015, 09:34 PM | #8 | |
04-14-2015, 11:12 PM | #9 |
I like teeth.
Time will remove it. About 4 to 6 months of time. The only reason you would have to reapply it, is if you left bugs on your bumper for more than a few days. Bug guts are acidic and can penetrate the sealant. So as long as you care to remove the bugs on a regular basis, you can expect 4 to 6 months of coverage.
04-16-2015, 03:17 AM | #10 | |
04-16-2015, 07:26 AM | #11 | ||
I like teeth.
04-16-2015, 01:31 PM | #12 |
Drives: 2017 Camaro 1SS 1LE Hyper Blue Join Date: Mar 2013
Keep it simple first, WD-40. I am sure you have some already and it won't harm anything. I made that suggestion to a Coworker and he tried it, came back and told me that the tar that was on his car came right off with the WD-40. Spray it, let it sit a few seconds and wipe away. If that doesn't work then get more aggressive with it.
04-16-2015, 06:11 PM | #13 | |
04-16-2015, 06:30 PM | #14 | |
I like teeth.
In my opinion, more headache than it's worth. A little extra work, but more safety, if you use something like a Bug and Tar remover that is designed for cars. Those are petroleum based, so they are solvents as well.
