Old 03-04-2018, 08:36 PM   #1
Gotit4cheap16
Drives: Victory Red
What can i make on e85/Flex fuel with this setup?
LSA Blower
Zl1 lid
CAI
160 Thermostat
Speed Daddy Headers
2.5 upper pulley
Tick Performance STOCK Converter Camshaft for LS3
Flex fuel sensor
FIC 127lb 1300cc Injectors
Livernois Firestorm Dual Fuel Pump
Gotit4cheap16 is offline   Reply With Quote
Old 03-04-2018, 08:57 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
low- mid 600s need more boost to make more
ttshovel is offline   Reply With Quote
Old 03-04-2018, 09:35 PM   #3
Gotit4cheap16
Drives: Victory Red
I might get a 9.1 lower pulley then after im settle in about a couple of months and retuned along with a viramax intercooler pump. What do you think my 1/2 times would be?
Old 03-04-2018, 09:50 PM   #4
ttshovel
ttshovel's Avatar
not a clue on times. I ran a 9.55/2.50 upper on e85 when I was using an lsa. ran 10.30s in 1/4 with a 4l80. would've been much faster with the 6l80/90 or more converter. main issue was geat soak. after a few passes it was down 10mph and 7-9 tenths
Old 03-21-2018, 02:01 AM   #5
2010SSRSM6
2010SSRSM6's Avatar
Originally Posted by Gotit4cheap16 View Post
LSA Blower
Zl1 lid
CAI
160 Thermostat
Speed Daddy Headers
2.5 upper pulley
Flex fuel sensor
https://www.facebook.com/13972157941...5527444171135/
