09-03-2013, 04:32 PM | #1 |
Mike
Sprint Booster
Saw this on Gearhead Garage today and wondered if anyone has installed them on their ZL1? If so, what were the results.
http://www.sprintboosterusa.com/default.aspx |
09-03-2013, 04:49 PM | #2 |
Drives: 2013 ZL1. Black on Black on Black Join Date: Aug 2013
Im curious as well....but very very skeptical!
09-03-2013, 04:54 PM | #3 |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
Saw that too and found a dealer...price was $299. At that price might as well get tuned.
09-03-2013, 04:56 PM | #4 |
Drives: 12 SIM 2SS/ RS Sinergy M6,GMC2500HD Join Date: Jan 2012
Tune won't get rid of the throttle lag!!
09-03-2013, 05:08 PM | #5 |
Drives: GM Join Date: Oct 2012
I've wondered about this as well. |
09-03-2013, 05:40 PM | #6 |
2013 ZL1
The way I read these you can tune the drive-by-wire throttle response
From GM High-Tech Performance: The custom tune attacks several areas in the ECM, and there are many highlights that the guys at ECS pointed out. At the top of the list was the drive-by-wire throttle response, torque management, and skip-shift functions. Each was modified to make the car more enjoyable to drive. Read more: http://www.gmhightechperformance.com...#ixzz2ds6m7inQ And Phastek Performance now offers Custom Performance Tunes via E-Mail for your 2010-2012 Camaro! Using the DiabloSport inTune or Trinity, or the SCT X3 Programmer, we can custom tune your vehicle to match YOUR specific aftermarket upgrades & modifications, increasing your horsepower, throttle response, and much more. All sent via E-Mail! Get the most out of your modifications today! Read more: http://www.phastekperformance.com/20...#ixzz2ds7B11dv |
09-03-2013, 05:50 PM | #7 |
Drives: 2011 Camaro SS Join Date: Dec 2012
Sure would.. Just depends on how the customer wants to ramp in the throttle pedal. Also a good ported TB and good CAI helps too As per the Sprint Booster... Its the same thing as a throttle booster that some tuners exclaim. All it does is changes the ramp-in rate and/or throttle position vs. pedal (Depending on the operating system/ECU). For a sheer example, if you are at 25% on the accelerator pedal, its really 50% open that the booster is commanding. So you think wow this car got really fast from just this. |
09-03-2013, 09:43 PM | #8 |
Jeremy Frye
Drives: 2016 Hyper blue 1SS Join Date: Jul 2010
So it just tells the computer that the throttle is just in a different position giving the feel of better throttle response? But doesn't actually change anything?
09-04-2013, 07:55 AM | #9 |
Drives: Camaro ZL1 Join Date: May 2012
Snake oil.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
09-04-2013, 08:36 AM | #10 |
Drives: none Join Date: Aug 2011
09-04-2013, 11:41 AM | #11 |
2013 ZL1
According to the tv show, there is built in lag time so when you press full throttle on the peddle it takes a second or 2 before the throttle plate gets wide open. Their demo shows reduced time for the plate response. Not just tricking it to a different position. Of course they only showed going to full throttle and not any points between or even holding so you could see it was a real demo. Still not worth it to me unless you are sure you will never tune.
09-04-2013, 12:10 PM | #12 | |
I've made plenty of passes at a drag strip and never felt or datalogged any kind of measurable lag from the time I stab the gas to the time the car moves. |
06-04-2014, 01:35 PM | #13 |
Drives: 2010 2ss camaro Join Date: Jan 2010
Finally got enough nerve to try the sprint booster,what a big difference in throttle response,my car was not lacking in that area to begin with,but the sprint boost does give the car an even better response. I have a tune,lt headers,ported throttle body and cai installed,it make the car even more fun to drive and the exhaust note is a joy to listen to upon each gear shift from my a6. Well worth every penny! It comes with a 30 day money back warranty,but I think this will be a keeper.
06-04-2014, 03:35 PM | #14 |
Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
They work pretty good I've used them on my 370z,but as stated above a good tuner can make it do the same.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 |
