Old 03-30-2015, 10:59 AM   #1
Joker853
Joker853's Avatar
Drives: 2010 Camaro 1SS
Bad alignment =. Horrible tire tread life
So I had about 800 dollars worth of suspension work (bushings, toe links, etc.) installed at a local md ship before I moved down here to Florida, and an alignment done. Moved to Florida a month later, bought new BF Goodrich Comp Sport 2 tires to the tune of around 1000 bucks after warranties and all that. 3,000 miles later, the inside of the rears are already bald....does this sound accurate? Should I be calling the alignment shop? WOW...got me even rethinking on getting another pair of summer tires in favor of some all season longer range tires...smh
Mods:
Stainless Power 1 7/8" Long Tubes, High Flow Cats
Flowmaster Outlaw Axle-back
CAI Cold Air Intake
Barton Short-throw Shifter
JRE Custom Tune w/ Diablosport Trinity
SLP Front Splitter
Joker853 is offline   Reply With Quote
Old 03-30-2015, 11:51 AM   #2
Mike_G
Drives: 2010 2SS/RS
did you get alighnment specs from first shop when it was done? Are you lowered? Do the wheels look to have excessive negative camber? be curiouse to see toe and camber settings.
Any track time? Definately something off if you went through them in 3000 miles...
Mike_G is offline   Reply With Quote
Old 03-30-2015, 12:31 PM   #3
Joker853
Joker853's Avatar
I am lowered an inch, they didn't look that cambered...no track time and I drive a little spirited, but hardly ever burning out. I've done reviews on the comp sport 2's...nobody ever talked about tire wear being an issue. :/
Mods:
CAI Cold Air Intake
SLP Front Splitter
Old 03-30-2015, 03:43 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
It sounds like your Camber is out!
Old 03-30-2015, 04:02 PM   #5
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Probably more so toe than camber, yes camber will wear out the inside a bit, but toe will really kill them in a hurry.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 03-30-2015, 04:24 PM   #6
EM1/SS
Drives: 11 2SS/RS M6 vert
I got a bad alignment when I did all my suspension mods. In a year it took the inner third off the rears. The alignment shop tried to say I must have hit something.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 03-30-2015, 04:26 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Alignment...
Mods:
Old 03-30-2015, 04:27 PM   #8
Rob@WretchedMS
Drives: His Wife Crazy
Get us pics of the tire wear,
do you have a printout of the alignment?
Rob@WretchedMS is offline   Reply With Quote
Old 04-03-2015, 10:08 AM   #9
Pr0j3kt1
Pr0j3kt1's Avatar
Drives: 2010 2SS
Had an alignment done on mine. 5000 miles later, I needed new tires. Took the opportunity to upgrade.
I actually made a trip Virginia to San Diego and back.
2010 2SS Orange on Black
JBA LT, HF Cat, JBA Muffler, Pfadt Drop Springs, Razzi Body Kit
2014 Silverado
6" Fabtech, 35 Baja ATZ, FloPro Catback
Pr0j3kt1 is offline   Reply With Quote
