Old 04-04-2015, 06:23 PM   #1
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
HELP....
Ok... So I changed the Calipers, Rotors and Brake Lines. I Bled the brakes starting with Passenger Rear inner bleed screw first then outer. Then same process on Driver Rear and then Passenger Front and then driver front. The brakes are spongy....so I bled them again and no air came out. Still spongy. What the hell is going on?
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 04-04-2015, 08:03 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
How are you bleeding them?
Rob@WretchedMS is offline   Reply With Quote
Old 04-04-2015, 10:03 PM   #3
BRAVO 2SS
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
I have a Motive Power Bleeder. So pumping it up to 15 psi and then going to bleed screw and opening it with tube attached and closing it when no more air.
2010 Camaro 2SS/RS
