01-20-2011, 05:12 PM | #1 |
Drives: 2010 Camaro LS, 1973 Corvette Join Date: Dec 2010
Rotten Egg smell from A/C - Defrost?
Has anyone had this issue? It smells horrible sometimes when I have the A/C on with the defroster. I have an appointment Monday and want to have all the ammo I can.
01-20-2011, 05:18 PM | #2 |
ou mai gad
Drives: SW 2SS x2 Join Date: Feb 2010
Not had a problem yet, but I remember back in 2007 a cousin bought a Mazda 3 and the AC smelled like shit, took it to the dealer and they told her it was because she was using normal gas instead of premium..
HAHAHAHAHAHA Go figure...
01-20-2011, 05:27 PM | #3 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Just curious, do you have a passenger with you when this happens? Kidding aside it is common for earlier cars ( very common with chrysler products) to have a rotten egg smell when the converters are bad but have not heard of it with these cars especially where as they are still new.
01-20-2011, 07:14 PM | #4 |
Drives: 2011 1SS A6 Join Date: Aug 2010
Happened to me once after a rain storm. Put the defrost on and wow what a smell. Hasn't happened since so I haven't thought much of it. Curious to see what they say.
01-20-2011, 07:21 PM | #5 |
Drives: VR 2ssRs Join Date: Sep 2009
My wife's rav4 was smelling like that 2 days ago, turned out to be corrosion forming on one of the battery terminals. Man did it stink up the garage
01-20-2011, 08:41 PM | #6 |
Drives: Truck Join Date: Apr 2010
I had that problem and took it in for repairs. They removed 3 rotten eggs and after that, everything was fine.
01-20-2011, 09:34 PM | #7 |
Drag Racer
Drives: 2010 2SS/Rs Join Date: Dec 2010
thebatterys smell like that when they go bad its hORRiBLE much worse than that of a real rotten egg.
01-21-2011, 08:06 AM | #8 |
Emerald Coast Camaros
I heard that too about the battery.
Had: 69' RS, 78' Z28, 98' SS Have: 2010 1RS/SS |
01-21-2011, 08:59 AM | #9 |
I've not smelled a car battery that went bad, but I have had sealed lead UPS batteries go bad. The best way I describe those is like burnt electronics mixed with urine.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
01-21-2011, 10:52 AM | #10 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Might have some mold and mildew build up. They should check the drain make sure it's draining. There is also some spray stuff to use to kill all the funk growing in there.
One thing that helps after it gets cleaned out, is to turn off your A/C - Def before turning the car off. And kick the fan up. Especially in high humidity. This helps to dry off the evap core before parking the car. |
01-22-2011, 09:09 PM | #11 |
Drives: X-15 Velocipede Join Date: Mar 2008
Defrost mode brings in outside air through the cowl.
The smell is a temporarily rich condition in the engine, that causes the catalytic converter to emit a rotten-egg odor. Normal operation on all cars. When airflow direction is towards the cowl, from the exhaust tailpipes, you get the smell. |
01-27-2011, 10:27 PM | #12 |
Problem is mine isn't temporary. When it's below freezing it doesn't seem to happen, but today (40 degrees), it will continue to smell like hell forever....unless temporary is over 10 minutes or so, until I can't take it any more..
02-15-2011, 07:39 PM | #13 |
Drives: 2011 2SS Join Date: Jan 2011
I just had this happen to me today. Damn what a horrible smell! Problem is the air wasn't even on. I accelerated quickly and it got even worse.
02-16-2011, 01:34 AM | #14 |
the clutch ?
Similar Threads | ||||
New car smell too strong, give us a Headache? | CamaroSS_LS3 | 5th Gen Camaro SS LS LT General Discussions | 41 | 07-06-2009 02:25 PM |
Bad smell from 2007 Avalanche A/C vents? | Mavtop | General Automotive + Other Cars Discussion | 3 | 06-14-2009 10:57 PM |
