Old 04-11-2011, 10:01 AM   #1
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Sounds sortof like an exhaust leak...but??
Anyone else have a slight exhaust leak noise from the passenger side of the motor?
This only happens when the engine is very well warmed up and under a load/accelerating. It's sort of a flapping sound/ deck of cards thumb shuffle
I see no evidence of a leak and suspect it may be something normal that I am simply unaware of.
It started at about 1000 miles and I have 5000 now.
f5journal is offline   Reply With Quote
Old 04-11-2011, 10:52 AM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Do you have headers?
JLE58 is offline   Reply With Quote
Old 04-11-2011, 10:55 AM   #3
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 04-11-2011, 11:17 AM   #4
f5journal
f5journal's Avatar
Totally stock. I've been waiting to go to the dealer until I have at least a couple issues to address.
The sound I'm asking about seems to start when you get to 2800-3500 rpm under a load. It's not there under simple driving around town
Old 04-11-2011, 12:49 PM   #5
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
check the manifold bolts if they are missing the heads.(broken)
canadian ss is offline   Reply With Quote
Old 04-17-2011, 11:38 AM   #6
JLE58
I would say you have a leak somewhere. They are hard to find sometimes. The valve train on these cars are somewhat loud just like most every other LS and late model Gm motor long tube headers will really magnify the sound but since you do not have them i would just take it to the dealer and tell them to fix it riding around with leak will only make it worse if thats what it is. Maybe you can post a video that would help.
Old 04-18-2011, 08:30 AM   #7
f5journal
f5journal's Avatar
I'm taking it to the dealer. I has to be a leak. I had George at MGW install a shifter Friday and the minor jostling of the transmission and engine made it slightly worse. So it has to be a leak
Old 04-18-2011, 08:48 AM   #8
Muck_Fustangs
Muck_Fustangs's Avatar
Drives: 2011 Chevrolet Camaro
Send a message via Yahoo to Muck_Fustangs
if its stock... let the dealer handle it eyes closed...
Muck_Fustangs is offline   Reply With Quote
Old 05-09-2011, 06:55 PM   #9
DVAS
Drives: 2011 Camaro 2SS
Any news on this? I am taking mine to dealer for the new exhaust on my 2011 ss manual, but not totlaly sold it is the issue until it quites up after service... So paranoid
Thanks
DVAS is offline   Reply With Quote
Old 05-10-2011, 07:39 AM   #10
f5journal
f5journal's Avatar
Nothing yet...have not been to dealer. It's not at the engine to manifold and I checked the manifold to pipe joint..that is tight also
Old 05-10-2011, 08:16 AM   #11
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I started to notice a similar sound (does sound like cards shuffling) same RPM range and while accelerating. Please post when you get it figured out.
nancygrl is offline   Reply With Quote
Old 05-13-2011, 08:53 AM   #12
Grandeos
Automotive Designer
Grandeos's Avatar
Drives: 2011 Camaro 2SS/RS (LS3)
Sounds to me like the same problem I had on my 2LT, and now also on my 2SS. Is it a "rustling" noise??? Sounds like its coming from the passenger floor board under 3k+ acceleration???
If so, then its the heater core inlet valve that needs to be replaced. I had this done on my 2LT, and will be taking my new 2SS in soon for the same exact noise. There is a TSB for this issue.
2011 Camaro 2SS/RS LS3 (SIM/BLK)
Grandeos is offline   Reply With Quote
Old 05-18-2011, 03:22 PM   #13
DVAS
Any updates?
Old 05-20-2011, 11:19 AM   #14
FLYBOY
FLYBOY's Avatar
Drives: Black 2010 2SS/RS A6
I have this exact noise also. Mine crops up above 3k RPM all the way through the power band coming from what seems like the passenger floorboard or low passenger firewall area. I'm thinking it's either a leak or a loose shield. I have a hard time thinking it's the heater core, doesn't sound like fluid it's more of a small metallic clank. At first I thought it was bad gas and I was experiencing preignition, however, I have used nothing but 91 octane and have done several fuse pulls...I'm curious if anybody has solved this problem yet?
FLYBOY is offline   Reply With Quote
What exhaust do you think sounds best V6 only NoFatChx Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 06-17-2016 11:00 AM
I think I may have an exhaust leak..or what it is f5journal 5th Gen Camaro SS LS LT General Discussions 3 10-21-2010 12:14 PM
wow 2008 m5 with eisenmann exhaust sounds really good mikeSS General Automotive + Other Cars Discussion 6 07-05-2010 11:37 AM
Brief Acceleration and exhaust sounds pharmd Camaro Photos | Spyshots | Video | Media Gallery 6 10-07-2009 10:30 PM
