Old 04-08-2024, 11:54 AM   #1
krest509
Drives: Rs 2011
2011 Headlight help.
Hey guys
Can You guys give me a good place
Where to purchase new headlights ?
It’s time to change them .
A friend told me he can repair them but I think they are beyond repair
Thanks
2011 RS 3.6
krest509 is offline   Reply With Quote
Old 04-08-2024, 12:27 PM   #2
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
If you wet sand the oxidation off of them and then re clear them they will look new, and last for a good while. Don’t skip the clear, they will oxidize right back if you do.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 04-08-2024, 01:18 PM   #3
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
What Aqua said... Pull the front bumper off to get better access and sand all of the oxidation off wet sanding. Then spray a high quality automotive grade 2k clear and they should look good for a long time. They key is a quality clear coat. I have had headlights look good for many years doing it this way. The kits at the parts stores only work for a short period of time.
If you just want to replace them, look for a set of factory used ones. Those halos are hard to replace without buying oem. Just buy from someone who can prove that they were working prior to removing, or buy from a seller with a warranty. Maybe try ebay? Or Leecparts . com
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 04-09-2024, 03:40 PM   #4
krest509
Drives: Rs 2011
Thank you guys .
I wasn’t going to purchase the ones below on eBay .
But I think I’m going to do the project
The last guy that painted my bumper painting one of my headlight slightly hopefully I could remove the paint and clear quotes 🤦
Check out the pictures below what do you guys think
Old 04-10-2024, 02:15 AM   #5
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Looks good, but they are halogens.(not HID)
If you don't need to drive in the dark, halogen is fine too.
Btw. I'm always drooling,Bluebagger06 headlights.
Old 04-21-2024, 03:03 PM   #6
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Just swap to LED or HID bulbs? Lol
You can quite literally just swap to LED or HID bulbs that use that same halogen bulb socket size…. Lol The bulb hole alone, should accomodate for the other types of bulbs to fit. I’ve yet to find a modern headlamp assembly that doesn’t allow for halogen to HID or LED bulb swaps.
There shouldn’t be an issue, even though it supposedly uses halogen projectors instead of HID or LED ones. I’ve done this before in cars with halogen projector headlamps, and haven’t really blinded anyone. If you are, then it’s most likely using a NON-PROJECTOR headlamp housing, with traditional reflector housings…
TheBrightSide is offline   Reply With Quote
Old 04-22-2024, 02:21 AM   #7
chevy pilot
Led works fine in projectorlamp.
