Old 05-23-2012, 12:16 AM   #1
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
tire pressure problem
keeps telling me my tire pressure is low, but its not. filled the tire but still telling me its low
Khmero215 is offline   Reply With Quote
Old 05-23-2012, 12:18 AM   #2
Cam2011
Cam2011's Avatar
Drives: 2011 Camaro 2SS/RS
Try the other tires.
Cam2011 is offline   Reply With Quote
Old 05-23-2012, 12:39 AM   #3
Khmero215
Khmero215's Avatar
I filled the other tires. they seem to be fine
Old 05-23-2012, 12:42 AM   #4
J-ROD-210
J-ROD-210's Avatar
Drives: 2010 Camaro SS/RS RJT A6
Try the re-learn tire pressure
J-ROD-210 is offline   Reply With Quote
Old 05-23-2012, 01:08 AM   #5
Khmero215
Khmero215's Avatar
Did that too....couple of minutes later, same problem
Old 05-23-2012, 01:19 AM   #6
Bonemaro
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
:troll:
Bonemaro is offline   Reply With Quote
Old 05-23-2012, 01:40 AM   #7
djsnoflake
Faith Keeper
djsnoflake's Avatar
I had that once but I also had to do some worknand unhook the battery anyways. Cleared itself up after I hooked battery back up bout an hour later.
If that doesn't work, go to the dealer if its under warranty still.
I don't see how this is a troll post, those little sensors screw up sometimes.
Old 05-23-2012, 05:12 AM   #8
Waste
Drives: 2012 Camaro 1LT M6
I'm having the same issue, my rear passenger tire is always about 8 PSI lower then all of the other tires yet when I check the tire pressure manually it doesn't read the same thing. I was going to have the dealership check it out on my next oil change/service.
Waste is offline   Reply With Quote
Old 05-23-2012, 08:30 AM   #9
Chevrolet Customer Svc
Drives: GM Vehicles
Please let us know how service goes and if they were able to diagnose the issue you are experiencing. If you have any additional questions, comments, or concerns, please don't hesitate to contact me via PM.
Brandon
Chevrolet Customer Service
Old 05-23-2012, 08:36 AM   #10
PsychoZL1
PsychoZL1's Avatar
Drives: 2015 Challenger SRT
I've found that the TPMS sensors in my Camaro read 3 psi less than what's actually in the tires. Maybe this is the case and it is reading low enough to give you the low pressure warning.
What happens if you increase the psi in your tires? Does the warning go away?
PsychoZL1 is offline   Reply With Quote
Old 05-23-2012, 08:55 AM   #11
Khmero215
Khmero215's Avatar
I increased the pressure in all the tires to see if its just that one tire. all the sensors picked up the other 3 increases but not the 1 tire.
I'm sure I voided my warranty with all my mods
Old 05-23-2012, 09:34 AM   #12
Coltrane
Drives: Camaro
[QUOTE=PsychoRS;5009128]I've found that the TPMS sensors in my Camaro read 3 psi less than what's actually in the tires.QUOTE]
THIS.
Coltrane is offline   Reply With Quote
Old 05-23-2012, 10:59 AM   #13
RallySS
RallySS's Avatar
Drives: 2011 Rally Yellow RS/2SS Vert M6
Pretty sure your mods don't void TPMS issues unless they have been modded. I would bring it up to the dealer or just order a new one, have it installed and do a relearn. Keep batteries on hand for them when you have your tires changed also if the batteries can be replaced, it will save you some time and money down the road.
If you expect to score points by whining, join a European soccer team.
RallySS is offline   Reply With Quote
