#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 05-07-2019, 05:05 PM   #1
2015 1LE SS
2015 1LE SS's Avatar
Drives: 2017 2SS
Defeat CEL for new exhaust without NPP
Hey guys, I'm putting the Corsa Extreme Cat-Back on a ZL1 1LE. When i unplug the NPP I hear it throws a CEL. Is there a plug i can plug into the NPP plugs to trick it into thinking the valves are still there?
2015 1LE SS is offline   Reply With Quote
Old 05-07-2019, 05:15 PM   #2
srcstc
Drives: 2016 Camaro 2SS
I thought it didn't throw a CEL.
srcstc is offline   Reply With Quote
Old 05-07-2019, 06:49 PM   #3
enzia35
Drives: '16 Garnet Red 1SS
Unplugging the NPP shouldn't throw a code. Wrap up the plugs well or heck I think someone sells blank plugs.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 05-07-2019, 07:09 PM   #4
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '18 1SS 1LE
If the cat-back deletes the secondary cats you're probably getting a CEL from a leak at the drivers side cat connection. Pretty typical. I swapped to a non-npp axle-back, no CEL from that.
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2
Chocolate Apocalypse is offline   Reply With Quote
Old 05-07-2019, 08:20 PM   #5
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I've heard that pulling the AFM actuator on an SS with the A8 throws a CEL but not NPP. I pulled the NPP fuse on my 2SS and it didn't throw a CEL. If pulling the NPP throws a CEL on your car then you can unbolt the actuators from the exhaust, leave them connected to the wiring harness, and tie them up out of the way. That's how the SS A8 people avoid getting a CEL when they remove the AFM valves from their exhaust without a tune.
Mark114 is offline   Reply With Quote
