12-02-2014, 12:24 AM | #1 |
Drives: 2011 Camaro 2SS Join Date: Jul 2013
FS: HyperTech Max Energy Power Programmer
Bought this off an old member here who moved over to a Mustang and no longer had anymore use for this. Great programmer for the money and works with either the automatic or manual V8's. Unmarried of course and recently updated. More Info:
Hypertech's Max Energy power programmers extract every bit of energy possible from every molecule of fuel, increasing miles-per-gallon at part throttle and horsepower at wide-open throttle. Max Energy programmers are even Internet updateable with the include USB cable. Additional features (depending on the vehicle application) include: * Raise the top-speed limiter to match the speed rating of high performance tires * Raise the engine's rpm limiter for increased performance * Adjust individual automatic transmission shift points and shift firmness * Recalibrate speedometer and odometer for non-stock tire sizes and/or gear ratio changes * Lower the cooling fan on/off temperatures to match the thermostat rating * Read and clear diagnostic trouble codes and turn off "check engine" lights * Ability to adjust settings or go back to stock calibration at any time $125 shipped |
12-04-2014, 05:58 AM | #2 |
To the top!
12-06-2014, 03:31 PM | #3 |
Really wakes up the car with very little technical knowledge or effort. Plus the ability to be able to read and clear codes.
12-06-2014, 04:19 PM | #4 |
Drives: 13 Ashen Gray 1SS/RS Join Date: Oct 2014
And this programmer will allow you to turn off AFM if you have an automatic. I just bought this same programmer and I am happy with it.
12-09-2014, 04:51 PM | #5 |
Thanks TBone07, glade you like it.
12-10-2014, 07:59 PM | #6 |
'It's an experiment'
Still have it?
