Old 03-12-2014, 12:49 AM   #1
rouchiemanz28
rouchiemanz28's Avatar
Drives: 1998 z28
1LE "ENGINE POWER REDUCING"
I purchased my 14 Black 1Le 1ss about 3weeks ago with 27 miles on it and been loving it ever since. Until today. I'm driving about 55-60mph, because of the break-in rule, when my dash lights up with "ENGINE POWER REDUCING". sO, I quickly start to slow down and find a spot to pull over. As I pull over every light in the dash lights up. I kill the engine and let it sit for a minute before trying to start it again. When I turned the key the info dash said PRESS THE CLUTCH TO START, and I was. I hit the onstar button they did a reading and said there was two readings, engine and tranny, get it to your local dealer ASAP. What the HELLLLLLL???
Has anyone had this problem?
ASS WHOOPER!!!!!!!
rouchiemanz28 is offline   Reply With Quote
Old 03-12-2014, 08:15 AM   #2
Camaronutt
Drives: 68 Camaro--2009 Corvette
Stuff happens, even to news cars!
Camaronutt is offline   Reply With Quote
Old 03-12-2014, 08:27 AM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
REP "reduced engine power" can happen after a tune with HPT if its been tuned with that it will clear....if its not been tuned and you just bought it then take it to the dealer for sure
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-12-2014, 08:44 AM   #4
rouchiemanz28
Drives: 1998 z28
Thanks man, but the car has never been tune or driven hard, yet. It has 637 miles on it now. I will be taking it to my local dealer today.
ASS WHOOPER!!!!!!!
Old 03-12-2014, 08:46 AM   #5
1KillerSS
1KillerSS's Avatar
good luck and i hope its nothing serious...if it makes you feel any better ive got 35k miles on my 1ss and i drive it like i stole it ***in Mexico of course***and have had very few issues so dont let it keep you down
Build thread
Old 03-12-2014, 08:48 AM   #6
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
There's so many things it could be, But engine power reduced could be an internal short in the throttle body. Since they are electronic(along with almost everything else...steering too) and not drive by wire, it could have failed. No big deal, that's what warranties are for. Unfortunately new cars break and this is not common. You have free roadside towing for 5yrs or 100K miles from the original purchase date. 1(800) CHEV-USA
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 03-12-2014, 08:57 AM   #7
DaemonGPF
Redonkulous
DaemonGPF's Avatar
Drives: Camaro
No good. At least you're finding this out right away. I'm just over 600 miles on the ticker myself. I hate hearing stuff like this, however. Really shouldn't happen in a brand new performance car but unfortunately it does.
DaemonGPF is offline   Reply With Quote
Old 03-12-2014, 11:12 AM   #8
rouchiemanz28
Drives: 1998 z28
Just eased it in to the local Chevy dealer. We'll see
ASS WHOOPER!!!!!!!
Old 03-12-2014, 11:15 AM   #9
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
"Welcome to the party, pal."
-John McClane
Also, any mods to it?
The same thing happened to mine because after the catch can install I forgot a connector.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-12-2014, 11:26 AM   #10
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
like davidcroft says... probably a wiring issue with the throttle body. when there is a problem, it goes into that reduced power mode for safety because it can't read throttle position
maddoggyusa is offline   Reply With Quote
Old 03-12-2014, 12:01 PM   #11
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Be glad it happened B4 you modified it .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-12-2014, 12:54 PM   #12
TOYMARO
TOYMARO's Avatar
Drives: 2011 Camaro SS/RS 2SS
same message for me when i left the throttle body connector OFF after a cc install. LOL, my bad
TOYMARO is offline   Reply With Quote
Old 03-12-2014, 02:29 PM   #13
rouchiemanz28
Drives: 1998 z28
Got my car back from the local dealer. They said it had two History codes that were cleared and they drove it to make sure they didnt reappear. But couldnt really explain the codes. Well it's running fine now. And no it's not modified yet. I have an slp axle-back and k&n cai in the box.
ASS WHOOPER!!!!!!!
Old 03-12-2014, 02:45 PM   #14
GONIF
GONIF's Avatar
Some times an over oiled K&N filter can get oil on the maf and cause a code .
1le camaro, 1le problem
