03-10-2024, 10:32 PM | #1 |
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins Join Date: Jul 2015
AEM AFR wideband not working
I installed the AEM AFR wideband gauge yesterday. The gauge powers on fine. I've rechecked the power and ground.
After engine start the gauge goes full lean and displays dashes. The sensor is heating up. I've checked for exhaust leaks. I even tried holding a gas soaked rag next to the sensor and I can't get it to read anything other then full lean. Are sensor problems out of the box that common? Research seems to suggest the possibility but a lot of the articles are a bit dated. Has anyone experienced a similar issue recently? |
03-11-2024, 12:24 AM | #2 |
I just ordered another sensor. I'll report back
04-05-2024, 08:28 AM | #3 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Where in the exhaust did you install the 02 sensor?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
04-05-2024, 09:42 AM | #4 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
I had an issue with my wideband AFR guage as well. It would power up and everything but no readings. I bought a ls4.9 sensor off of Amazon because the reviews said that the cheap sensor actually worked really well and tada! It has been working for the last year with no issues. I'm willing to bet that your sensor is just dead.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
04-08-2024, 08:56 PM | #5 |
04-08-2024, 08:57 PM | #6 | |
