#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Wheels | Tires -- Sponsored by The Tire Rack
BeckyD @ James Martin Chevy
Old 11-02-2018, 09:48 AM   #1
BA RS
Big B
BA RS's Avatar
Drives: 2016 2SS Summit White
how to keep stock Black rims clean
So I just recently picked up 2016 2SS with black wheels and I am wondering how to keep them shiny. Is there a product that I can buy to put on them to keep them clean or at least make it easier to wipe off?
2016 2SS,NPP exhauset, A8, Black and White interior, black rims, black center stripe.
BA RS is offline   Reply With Quote
Old 11-02-2018, 09:51 AM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Read the link in my signature about wheels. Still the easiest way I've found to keep them clean
Glen e is offline   Reply With Quote
Old 11-02-2018, 10:28 AM   #3
BA RS
Big B
BA RS's Avatar
Ok thank you sir
Old 11-02-2018, 11:03 AM   #4
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I also put my DA polisher to them (factory black 5 spoke) using a 4 inch pad and they came out shiny, and I also changed my brake pads to the power stop pads and no more brownish looking wheels.
warren3537 is offline   Reply With Quote
Old 11-02-2018, 11:20 AM   #5
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
You MUST go to ceramic pads although the stopping power takes a hit.
Coat the wheels and calipers with a ceramic coating and follow Glens advice,.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 11-02-2018, 11:28 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
^ what he said. Change ceramic pads, you lose braking power but it's still more then enough unless you road course the car. Then ceramic coat the wheels.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 11-04-2018, 10:18 AM   #7
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Glenn: excellent overview. Hell, I can even follow it.
Question: have you tried Zaino tire stuff? I have a bottle of the Armor All you exampled; however, find the Zaino far superior.
Yea, I'm partial...however...
Chris
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
Old 11-04-2018, 10:50 AM   #8
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I had my wheels ceramic coated with they did my car. While it doesn't keep the brake dust from collecting on the wheels, it does make it come off very easily and keeps the brake dust from etching into the wheels themselves.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers)
Previous:
18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust)
16' F80 M3 (Ohlin R/T Coilovers)
13' Audi TTRS (APR Stage 1, MSS Springs)
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
TRZ06 is offline   Reply With Quote
Old 11-04-2018, 11:59 AM   #9
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
Ceramic brake pads, it’s truly the only way to avoid brake dust.
SPARTAN sui is offline   Reply With Quote
Old 11-05-2018, 04:41 PM   #10
70chevelleSS
70chevelleSS's Avatar
Drives: 2017 Camaro SS 1970 chevelle SS
Anyone care to recommend a good set of carbon ceramic pads for the SS four pistons?
70chevelleSS is offline   Reply With Quote
Old 11-05-2018, 06:26 PM   #11
ivan2333
Drives: 2017 Camaro SS 1LE
I just got mines replace on a ss 1le got the Power Stop Z26, FOR AN SS, see link below.
Power Stop K7226-26 Front and Rear Z26 Street Warrior Brake Kit
https://www.powerstop.com/product/po...ss=SS%20Models
ivan2333 is offline   Reply With Quote
Old 11-06-2018, 07:14 PM   #12
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
Ceramic coating or Chemical Guys wheel wax also works good. I ceramic coated mine and the wifes, but have used the wheel wax with good results.
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 11-07-2018, 03:24 PM   #13
SSnakeEater
Drives: 2016 Camaro 2SS
Be sure you change the rotors as well or at least re surface them. I made the mistake of just swapping out the pads and my car squeaks terribly now for the first few stops. It's rather embarrassing.
SSnakeEater is offline   Reply With Quote
Old 11-08-2018, 10:02 AM   #14
KingLT1
KingLT1's Avatar
I didn't have that problem but I changed the pads(PS Z26) when the car had 1500 miles. I just used a scratch cloth and brake clean on the rotors.
2016 NFG 1SS A8
