11-06-2018, 06:10 PM | #1 |
Drives: 2016 2SS 8AT Join Date: May 2018
Adjusting Afm(DoD) values (Results)
has anyone played around with the settings? Im wanting to raise the speed at which the vehicle needs to be going before it kicks in. Thinking about setting it up so it wont enable below 45 mph. Just wanted to see if anyone else has done anything other then just turn it off.
11-08-2018, 02:29 PM | #2 |
Big B
Drives: 2016 2SS Summit White Join Date: Aug 2009
where do you go in and find that?
2016 2SS,NPP exhauset, A8, Black and White interior, black rims, black center stripe. |
11-08-2018, 03:38 PM | #3 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Give it a shot, datalog it, and let us know how it goes. IMO 45 MPH seems too high a speed; the bulk of the FE gains you'll see from DoD is in lower load, which is going to be primary surface road and city applications.
What are the current settings doing that you don't like? It's an aftermarket ECM/TCM tuner.
2017 "M1SS1LE" in Hyper Blue w/PDR
11-08-2018, 03:48 PM | #4 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I think its the opposite...the majority of the gains from AFM is cruising in high gear on flat roads above 45mph. AFM does very little in the city other then annoy the shit out of most because it constantly kicks in and out.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
11-08-2018, 04:18 PM | #5 | |
Hot Dog
If that's the case, then go for it. Sounds like if the settings were adjusted further to keep it from engaging/disengaging so much in the city it may also improve the drivability.
11-08-2018, 04:30 PM | #6 |
CamaroFans.com
HP Tuners Software
^^This... just disable in all gears except 5th and 6th. |
11-08-2018, 07:28 PM | #7 |
as others have said its with using hptuners and its under fuel, lean/fuel savings tab
The reason I wanna change it is around town its kinda annoying since we have a lot of very steep grades and it will constantly kick in and out. With the drop in mpg after turning it completely off, I figured this would be the best of both worlds. I'll be out of town this weekend so when I get back I will try it and be the guinea pig. |
11-09-2018, 11:53 AM | #8 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Been awhile since I look at that table, but last I remember it isnt gear specific.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
11-09-2018, 12:00 PM | #9 | |
CamaroFans.com
There was a separate table showing each gear. |
11-09-2018, 01:32 PM | #10 |
Correct it cannot be adjusted by gear. So I'm sure this is the only way to do what I'd like it to do
11-09-2018, 04:10 PM | #11 | |
Drives: 2017 2SS Hyper Blue A8 Euro spec Join Date: Jun 2017
11-12-2018, 03:02 PM | #12 |
Just wanted to update this and say it was a success....kinda. It stayed off like I want it to and started @ 50mph. I had the settings set at 45 for the min vss,and 5 for the min vss hyst. The only reason I said kinda is after it turned on, I assumed due to the settings it would switch back to v8 mode if it went below 45 mph. It stayed on until I pushed the throttle (like normal) or came almost to a stop.
If anyone has any ideas about that please let me know. Im really happy with the results as it is. |
11-23-2018, 11:32 PM | #13 |
Drives: 2018 Camaro 2SS, Hyper Blue Join Date: Jun 2016
I had mine set to over 30mph and it worked well.
2018 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue, LT4 S/C, LT4 Fuel System, RotoFab CAI, Headers, HiFlo Cats
2016 2SS, A8, NAV, NPP, MRC, Sunroof, Hyperblue (GM buyback) 1999 Trans Am Firehawk, M6, headers, no-cats, slp exhaust, hot cam, intake, 3:73 gears. Red/Blk |
11-24-2018, 08:57 AM | #14 |
