11-07-2018, 01:58 PM | #1 |
Big B
Drives: 2016 2SS Summit White Join Date: Aug 2009
Question about some hidden features
So I am on a camaro FB page and some one said that if you use your key fob to unlock your doors that if you hold it down again for a few seconds it will roll the windos down. Is this true? I just recently got my 2016 SS and still learning all the things this car can do. I want to call BS on this but wasn't sure.
2016 2SS,NPP exhauset, A8, Black and White interior, black rims, black center stripe. |
11-07-2018, 02:01 PM | #2 |
Drives: 18 zl1 Join Date: Aug 2017
It's an option on in the radio hmi settings. you can turn the feature on or off.
I turned it on when I found out about it, tried it, and haven't used it since. |
11-07-2018, 02:03 PM | #3 |
Big B
oh ok cool. might have to check that out
11-07-2018, 02:19 PM | #4 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
You can only roll them down, not put them up which is a bit silly but it is a good feature nonetheless.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
11-07-2018, 02:40 PM | #5 |
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Yeah, something about NA regulations if memory serves me right. Had to have it programmed on my M3. Glad to hear the auto-down function is standard on the Camaro. I like to roll the windows down on hot days before I leave from work.
11-07-2018, 02:56 PM | #6 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
You can just hold down and it will unlock and roll the windows down. No need to release and re-press after unlocking.
02-28-2022, 11:01 AM | #7 | |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
I had it in a few Nissans, and when you're approaching your car in the hot summer months just that 2-3 seconds of the heat escaping the cabin is more useful than turning on the car remotely and letting the A/C try to cool the hot air that's stuck in the cabin. Too bad they can't create a sequence that rolls the window down then up after a few seconds, and then cranks the engine with the A/C blasting. |
