12-10-2011, 05:52 PM | #1 |
Drives: 2011 Camaro 2SS/RS LS3 (M6) IOM Join Date: Mar 2011
ADM Scoop install question
I just recently installed an ADM Scoop on my car, but I had a complication with the Horn Bolt. The instructions told me to use to supplied bolt with the existing Horn Nut, it's welding to the car. I have the scoop in, bolted on only with one of the washer bottle bolts. My question is, how is the new bolt installed? I cannot get my hand behind to install like the old bolt came out and if i install the bolt from the welded nut I cant put on the supplied nut or even tighten it.
Do I remove the washer bottle from the scoop to reach? Is the tab on the scoop supposed to go on the welded nut (would look weird) or flat on the other side of the horn nut? Picture shows horn nut/bolt area... not sure which way new bolt is supposed to go on or be tightened without taking front fascia off. Sorry if I confused anyone, I really dont now how else to explain it without you actually looking at it. Thanks guys! |
12-10-2011, 06:42 PM | #2 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
This might help.
http://www.camaro5.com/forums/showthread.php?t=90068 You use the new bolt - put it through from the front and thread it through the welded nut. Then put the ADM scoop tab on. Then put the other nut on to hold it in place. |
12-10-2011, 07:00 PM | #3 |
wow I have it way wrong then. I've seen that post a dozen times, sorry! hah, thanks a bunch... it just looked funny in my head with it sitting on top of the welded nut.
Thank you!! |
12-10-2011, 07:05 PM | #4 |
You're welcome. I had the same thought when I put mine in, but it fits fine that way.
12-10-2011, 07:11 PM | #5 |
I didnt read any of this stuff i just grinded the thing off >.< lols but i guess that works.
12-10-2011, 07:43 PM | #6 |
MIC
Drives: 2012 SSRS 6sp man Blk Join Date: Nov 2009
Is it difficult removing the inside fender liner? I am puuting one on but don't have car yet.
12-10-2011, 08:01 PM | #7 | |
Jack up the front left of the car, turn the wheels to the left. undo the torx screws and pop it out. There may have been few of those pins that you pop too? I can't remember for sure. But, it was easy. |
12-10-2011, 10:58 PM | #8 |
It was really easy... 3 torx at the front and 2I of the ouch pins and you can pull it back... I had access to a car lift and removed the front wheel... mad it a lil easier.... ill be finishing this early Sunday morning.... I swear I tried putting that bolt in so many times I think I spent like 30to minutes trying to get it before shop closed lol...
12-10-2011, 10:59 PM | #9 |
Push pins... excuse grammar please... forums on phone lol
12-11-2011, 08:01 AM | #10 |
MIC
Thanks for the expanation guys
12-11-2011, 08:21 AM | #11 |
What should I name my car
Drives: 2010 Camaro 2SS RS IOM Join Date: Jul 2009
I was confused when I got to that welded bolt too. I didn't remember reading anything about having to cut it off.
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat |
Similar Threads | ||||
My review of ADM scoop and Roto-Fab WW kit | ssmike | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 01-30-2012 07:53 PM |
FS: Roto-Fab WW relo kit and ADM scoop | ssmike | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 8 | 11-29-2011 10:07 PM |
Question on ADM guage install for wideband o2 | GMRULZ | Forced Induction - V8 | 3 | 10-21-2011 05:42 AM |
ADM Race scoop. How do you install it? | Pollock | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 04-28-2011 10:00 AM |
Just installed the ADM Intake Scoop | InvaderMoose | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 25 | 03-17-2011 10:26 PM |
