Old 05-06-2024, 09:15 AM   #1
thump426er
thump426er's Avatar
Drives: Z06
20x10 and 20x12 on 2010
Can’t find in my search wheels this size and offset but I’ve Found a set of wheels that I’d like for my car but rears are wider than I was expecting. They are currently on a 6th gen in the pic attached. Wondering if anyone knows how these will sit/fit on my 2010?
Specs are:
Fronts 20x10 with 6” backspace (sorry he told me backspace instead of offset) with a 255/40-20 on them.
Rears are 20x12 with 7-5/8” backspace with 305/35-20 on them.
Thanks for any input
I think in calculating offsets are +12.5mm front and +28.5mm rear
Edit: the offset numbers above are from using an online calculator. However when I add it myself I get fronts at +25mm and rears at +41mm.
thump426er is offline   Reply With Quote
Old 05-07-2024, 09:39 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
What wheels are they? I wanted to go with 12 wides on my rear, but was told by APEX wheels that I would have needed to go with a set of 19's to do that because there were NO 20's made that would fit the 5th gens.. So I currently am running 11.5 on the rear with a +30 offset.. Feradda FR3's..
Old 05-07-2024, 10:09 AM   #3
gtstorey
XO Luxury "Caracas Titanium Polished". https://www.camaro5.com/forums/showt...hlight=caracas
in 20x12 rear 315/34 and 20x10 front 275/40 with just a tiny bit of rubbing pitching it hard into a curve. But that is with all Z28 suspension plus solid subframe bushings.
Old 05-07-2024, 12:47 PM   #4
Leo72793
Drives: 2011 2SS/RS
interesting. whats your front wheel size?
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 05-07-2024, 01:39 PM   #5
thump426er
thump426er's Avatar
Drives: Z06
Gtstory, what are your offset numbers front and rear?
Old 05-07-2024, 01:41 PM   #6
thump426er
thump426er's Avatar
Drives: Z06
1JEWLDSSRS they are forgeline monoblock se1
Old 05-07-2024, 01:42 PM   #7
gtstorey
No clue. They were on the car when I got it.
Old 05-07-2024, 01:51 PM   #8
gtstorey
It wouldn't surprise me if it isn't the same as what is shown here for the corvette but I don't know for sure.
https://www.corvetteforum.com/forums...and-20x12.html
