Old 01-21-2011, 09:03 AM   #29
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
Originally Posted by flht99b View Post
Absolutely fantastic. I have 2 easy questions. The 3 bolt cam gear, did you use a GM gear or aftermarket and did you remove the oil pump to install a different one or the oil pump removal is necessary for a cam swap.
Thanks again for your outstanding post.
Ed M.
First of all thanks very much for the compliment.
As for your questions, the camshaft gear is a GM part, part# 12586481 (I have to update the parts list in my post with this). As for the oil pump, it had to come off in order to change the timing chain. It does not have to come off if you are only switching to a 3 bolt cam therefore switching out to the 3 bolt timing gear. My understanding is that if you are using a very mild cam that still makes use of the stock valve springs or even aftermarket springs on a cam without a lot of lift beyond stock then the stock timing chain is fine and would save you from having to take the oil pump off. In my case and most of the cam swaps you see here on the forum, the new cams have a lot more lift than stock (mine is in the 0.580" range and a lot of others are over 0.600"), possibly a more aggressive ramp rate on the cam lobes, and the valvetrain is upgraded with dual springs. These are all things that put a little more burden on the timing chain which I guess is why some folks upgrade the chain as some cheap insurance and why a lot of shops recommend to do so as well.
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 01-21-2011, 09:11 AM   #30
GenoSin
Drives: 2010 Chevrolet Camaro 2SS/RS
Wow...
Incredible DIY, however, I do not believe I will ever attempt this on my own vehicle lol...
GenoSin is offline   Reply With Quote
Old 01-21-2011, 10:35 AM   #31
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
excellent how to video. i learned alot. very impressive. i know your dads proud.
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 01-21-2011, 10:36 AM   #32
Camaro21
Drives: SOLD - 2013 M6 ZL1
All I can say is WOW !! Awesome write up with great pics and descriptions !!
Thanks for the post !!
Camaro21 is offline   Reply With Quote
Old 01-22-2011, 09:01 PM   #33
Stark
Stark's Avatar
Drives: fair to good
STICKY!!!!!
Well done Robert!!
Stark is offline   Reply With Quote
Old 01-22-2011, 10:12 PM   #34
Ivan @ Southwest Speed
Nice stripes!!!
Ivan
Old 01-23-2011, 07:26 AM   #35
SC2150
One of the best write ups I have seen. Great job!!
Old 01-23-2011, 10:32 PM   #36
SuperSport17
2010 2SS/RS LS3
SuperSport17's Avatar
Drives: '10 2SS/RS LS3
Impressive. I will definitely refer to this when im ready. U went over and above. Great job!
SuperSport17 is offline   Reply With Quote
Old 01-25-2011, 09:34 PM   #37
Jason@Phastek
Jason@Phastek's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek
What a Great Write-Up. The Best I have ever seen.
Jason@Phastek is offline   Reply With Quote
Old 01-27-2011, 07:04 AM   #38
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
AWESOME WRITE-UP!!!! STICKY TIME!!!
I piss excellence
and fart awesomeness
Old 01-27-2011, 02:54 PM   #39
Jacber
Drives: 2010 black camaro 1ss
great write up , where did you order your valve springs/push rods from and what part # are they?
Jacber is offline   Reply With Quote
Old 01-27-2011, 03:43 PM   #40
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
You're a moderator, do it yourself.
Old 01-27-2011, 03:48 PM   #41
robertway
robertway's Avatar
Thanks again everyone for their compliments...
The springs, retainers, seals, and seats all came from East Coast Supercharging in Cream Ridge, NJ which is only about 40 minutes away from me. They are Manley Valvetrain components as follows;
Dual Valve Springs: 221436-16
Titanium Retainers: 23623-16
Spring Seats: 42334-16
Valve Seals: 24042-8 (need two boxes)
I wound up picking up the pushrods from Jegs while I was out on the road for work. They are Comp Cams Hi-Tech hardened pushrods (Jegs link). Like I mentioned in the write-up I would make sure you measure for proper length as opposed to just duplicating someone else's setup. Whatever cam you wind up using may have a different base circle diameter than the one I used which would have a direct impact on what pushrod length you use.
Old 01-27-2011, 05:41 PM   #42
Jacber
thanks, will measure. leaning toward the katech torquer 3 cam.
DIY: Vararam CAI Install with Color Photos Jeanius Camaro DIY & HOW-TO instructions & discussions 22 05-26-2015 02:48 PM
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 10:08 AM
Camaro Heritage Grill DIY install (now with official GM install instructions). vuduman67 Camaro DIY & HOW-TO instructions & discussions 216 12-03-2014 05:18 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
