#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 12-23-2016, 02:15 AM   #1
Stryfe
Make America Fast Again
Stryfe's Avatar
Drives: 2016 HBM 1SS - M6
Differential Fluid Change
About to hit 2000 miles and want to change out my diff fluid.
I've read on here and in the manual that for Camaro's fitted with the LT1, you want 1.2 quarts of differential fluid. It also states to add the fluid additive.
The part number for the fluid is 88900401 and the additive is 88900330.
Now my question is, do I put in the 1.2 quarts of differential fluid AND THEN ADD the full 4 oz bottle of additive to it?
Stryfe is offline   Reply With Quote
Old 12-23-2016, 04:18 AM   #2
Max RS
Max RS's Avatar
Drives: 2016 SS AT
Add the additive first and follow up with fluid.
1969 Z-28, 302 4-Speed Sold
1989 350 AT Sold
2013 RS Convertible LFX AT Traded
2016 2SS AT
Max RS is offline   Reply With Quote
Old 12-23-2016, 01:04 PM   #3
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
Buy the oil with the additive already in it from GM. Shake it well and fill differential with 1.2 quarts of fluid or until it comes out of the bottom hole, about the same.
drivingagain is offline   Reply With Quote
Old 02-05-2017, 12:04 PM   #4
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
The correct P/N is 88862624 and you do not need to add the additive. Just did mine this morning at 1,800 miles and it was very easy. All you need is a 3/8 ratchet as far as tools are concerned. Use the slope on your driveway and ramps so you don't have to put all 4 corners on jackstands if you can't fit under.
I only had about 1L come out and it took about 1.3L so I'm wondering if they are slightly under filled at the factory.
Eric SS is offline   Reply With Quote
Old 02-05-2017, 01:56 PM   #5
Gunmetalmissle
Drives: 16 ngm ss
The owners manual was changed to specify fluid plus additive as opposed to just the ls fluid.
Gunmetalmissle is offline   Reply With Quote
Old 02-05-2017, 02:08 PM   #6
Eric SS
#becauseracecar
Eric SS's Avatar
There still seems to be some discrepancy. http://www.camaro6.com/forums/showthread.php?t=459727
Since I had no groan, I went with the oil without the extra bottle of friction modifier. A lot of people with the groan have changed the fluid without adding the modifier and had it go away as well.
Old 02-05-2017, 05:15 PM   #7
Gunmetalmissle
Drives: 16 ngm ss
Bad on GM for making this a guessing game. However, there is no discrepancy in my mind. Based on past GM vehicles the fluid that already has the additive never works well in the long run. Add to that all the diff problems people seem to be having with these cars.
To top it all off my local dealer claimed the computer system told them to use the non-limited slip oil and no additive in my SS. Obviously wrong. The head service manager did additional research and confirmed that the proper fluid is the synthetic oil plus the additional additive.
I'm trying to figure out who makes the lsd. I'm guess Eaton but not sure. On Eatons website they specify GM fluid plus additive OR castrol carbon mod. Carbon mod is the factory fill for the g8 and SS sedan.
Just trying to help someone from wasting their time/money.
Old 02-05-2017, 05:24 PM   #8
Eric SS
#becauseracecar
Eric SS's Avatar
Any input is good input on this subject! If it starts to groan I'll throw some modifier in it. My guess is Eaton as well but it would be nice to see it confirmed. The gear oil retails for $26/bottle but you can get it for much cheaper if you have a good parts guy at your local dealership. so it's not that big of a deal if I have to change it out again. Cheers!
Old 02-07-2017, 02:55 PM   #9
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Eric SS had it right. I've done exhaustive research, talked with GM engeineers ect. about this subject. Granted the "adding of the modifier is what the owners manual states" but GM (direct from the horses mouth) said by adding the number ending in 24 (already added) is the exact same thing. they did this to cut the confusion (if that makes sense). They are finding out its not the fluid, but more so on how the markings were on the gear set, wearing off not the fluid which is causing the clutch packs to make that growling noise. (hence the early flush). Now they are finding out that it could actually be the mfgr of the diff packs not correct. I just had my carrier replaced and so far so good. Although, once it hits 1500 miles again I am still flushing it.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-07-2017, 07:39 PM   #10
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
Thanks for this information - it's the most through explanation of the rear end groan issue that so many have been experiencing.
somewhatdamaged is offline   Reply With Quote
Old 05-30-2017, 06:06 PM   #11
evanescent03
evanescent03's Avatar
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4
did you use a transfer pump or just some creative pouring to refill? thanks!
evanescent03 is offline   Reply With Quote
Old 05-30-2017, 06:35 PM   #12
Eric SS
#becauseracecar
Eric SS's Avatar
I used a pump that you can buy at Walmart that screws into the top of the bottle.
Old 06-08-2017, 12:30 AM   #13
Tridon
Tridon's Avatar
Drives: 2017 2LT RS Hyper Blue Metallic V6
I know you all are talking about this relating to the SS, but is it also necessary to flush the differential in a V6 manual at 2k?
Tridon is offline   Reply With Quote
Old 03-25-2018, 02:40 PM   #14
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Does the car need to be level to drain this myself? I can put mine on ramps, I don’t have a driveway long enough where I keep it leveled since I live in a townhome.
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
