08-30-2017, 12:30 PM | #1 |
Drives: cobalt Join Date: Jun 2015
Best Place to get alignment?
Hey Guys,
Was looking for suggestions. For past cars I would normally just go to a firestone or Mavis , but was wondering if I should just go to a chevy dealership instead. Just a lot more expensive at the dealer. Anyone think it matters or have experience? Thanks |
08-30-2017, 12:33 PM | #2 |
Bigg Balls
In for the information as well. Seems being a newer car most alignment shop wouldn't have the specs unless you bring it to them. I have no idea how it works.
2017 Red Hot 1SS 8A..... Sold for a minivan
2024 Red Hot 1SS 8A.... No mods ..... yet |
08-30-2017, 01:01 PM | #3 | |
Drives: ZL1 Mosaic Black Join Date: May 2016
Last time I went to the dealership, an alignment was $200+ dollars. Depending on your driving style, I would not go to a cheap place...you'll regret it...in blood. |
08-30-2017, 01:04 PM | #4 |
Drives: 2017 1SS 1LE Join Date: Aug 2017
If you're just looking to get "in spec" - anyone can do that.
If you're looking for an autocross/track alignment, I see you're in NJ like me. www.sjfperformance.com is the place to go. Steve is an awesome guy, and an autocrosser. He'll do what it takes to get the specs you want (to the extent the hardware allows). We got 2.4 degrees out of camber from my stock 1LE yesterday. |
08-30-2017, 09:55 PM | #5 |
wow $200. My dealer charges $84 and at a shop that does fine spec alignments they charge $84 too.
08-30-2017, 09:59 PM | #6 |
Drives: 2016 Camaro SS M6 Join Date: Oct 2016
My dealer did mine for free. I went in for the cold rear diff grind to get the fluid change and mention the alignment. Got both done for free.
12-03-2017, 01:08 PM | #7 |
Drives: 2017 Camaro 1LE SS Join Date: Oct 2016
Some dealers suck some don't. It all depends but I've gone to Firestone and NTB and I had to walk them thru it but got good results. If you don't know how to help them then you probably need to go to dealer.
04-02-2018, 06:45 PM | #8 |
Drives: 2017 Camaro 2SS, MRC, NPP, Join Date: Jul 2016
I have had good results with my local firestone but I do "chat" with the tech and I always have a printout of the specs on the passenger seat. I believe their lifetime alignment is under $200. With the crap streets here in Houston I was taking my Charger in about every quarter. if you have a good, dependable shop I don't see why you wouldn't go this route.
04-02-2018, 09:18 PM | #9 |
Drives: 2014 ATS 2.0T 6MT Join Date: Mar 2018
By default all alignment shops do the same thing as your dealer: punch your VIN into the computer, mount the sensors and follow the prompts.
Only difference is a a good shop /dealer has the tools to do steering position sensor reset etc. and a REALLY good shop will actually do it right AND be able to do 'performance' alignments. And by right I mean follow all of the specs... Ie BMW requires weights in all 4 seats and a certain amount of fuel. All vehicles are suppose to have trim height verified before and after but most shops don't do it. A good alignment tech will jounce suspension between adjustments and recheck after a short road test... But if you are paying less then 2hrs nominal labor rate, you can bet you are not getting that level of service. In an effort to make the process faster/cheaper/easier the VIN pulls factory specs and the software adjusts visual cues accordingly. (they even have photos and video of how to make adjustments... Really designed for monkeys) If you want something other then stock, the display and print out will not be 'all greens'. Most standard shops (firestone) won't do anything but stock. One way to fool them into other specs is to give them the wrong VIN... ie my 2003 suburban was hard on the outside fronts and the problem only got worse when I went to 20"s. I found police edition trucks come with 20"s and different alignment specs to match so I found one on ebay, copied the VIN and with some photoshopping my local Firestone gave me the alignment I wanted without having to ask |
04-03-2018, 07:53 PM | #10 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I just had the track alignment done at my local dealer. They did a good job.
04-04-2018, 10:08 AM | #11 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I got my track alignment at my local dealer and it went really well. Was around $120 at the end, but that was because it does take a little longer to hit the tighter tolerances of the track alignment. My expectation is that it should still be around $80-$100 wherever you go, but don't be surprised to pay a little more if you're getting the track alignment. No matter where you go, easiest thing to do is to have the GM literature open with the specs you want it set to. Most shops won't have any issue doing a specified alignment for you if it's in writing by the OEM. Just have to talk to them a little and explain the situation in my experience.
2017 SS 1LE.
04-04-2018, 10:57 AM | #12 |
I used to be Dragoneye...
If you just want it "in spec", go anywhere that won't scratch it or drop it off a lift.
If you're headed to the track and really want it dialed in; find a performance-oriented dealer or performance shop with modern equipment and a willingness to let you in the back to work with the tech on your alignment specs. Hard to find...but worth the cost and search. |
04-04-2018, 11:06 AM | #13 | |
Also to add on, if you go to the dealer, try to find one with those laser thingamajig in their shop. My local has it and I go there to get it right.
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
04-15-2018, 11:31 AM | #14 |
Drives: 16 2SS Convertable Join Date: Feb 2018
I’m starting to think some people just lay down and take it, lol. I work my dealer, “hey, you guys match price service right? . Cool this dealer offer alignments for 79, here’s the coupon. It might help that I have like six Chevy dealers within an thirty minute drive.
2SS Convertible A8, NPP, GMPP CAI, Flow tie grill, Mishimoto Oil catch can, Eibach lowering springs.
