Old 07-15-2014, 09:13 AM   #1
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Drives: My wife crazy!
Turning LS3 into 427ci
Hi Gents,
Hopefully this is the right section. I have started doing research and searching forums. From what I have found so far reaching is the following.
The LS3 376cui with a 4 inch crank shaft will become 417cui. Now what are my options to hit that 427 cui mark? Just a set of oversized heads?
I have a mild/semi aggressive cam, headers, cai right now and really like staying NA with a 100 shot or so.
M3hta1 is offline   Reply With Quote
Old 07-15-2014, 09:20 AM   #2
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
The 427 LS3 has a 4.1" or 4.125" crank. You get to 427 the same way you get to 416.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 07-15-2014, 03:07 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's a reason most people stop at 416. The stroke required for 427 is a little much for the stock LS3 block. It can and has been done but the 416 is much safer and easier on the engine.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-15-2014, 06:55 PM   #4
Fallout
Mid Florida Camaro Club
Fallout's Avatar
Drives: 2012 Camaro SS Ashen Gray
Stick with the 417, in case you want to go bigger with the nitrous or move to a blower. If you plan on a 100shot and are not going bigger you could get away with the 427.
ECS 1500 supercharger blacked out, Alkycontrol, Livernois Duel Pumps, PRC 255cc aftermarket heads, FSP cam, DSS 9" with 3.55, ARH headers, magnaflow exhaust, Century Level 5 4l80
741 RWHP and 602ft-Lbs
Built By Florida Speed and Power
Coming soon YSI and to the moon
Fallout is offline   Reply With Quote
Old 07-15-2014, 07:12 PM   #5
c-57d
Drives: 14 2SS/RS Triple Black Ragtop LS3
"Just a set of oversized heads?"
Huh?
Heads do not change the displacement.
Just a FYI .
c-57d is offline   Reply With Quote
Old 07-15-2014, 07:15 PM   #6
jrhagen
Banned
Drives: Camaro
Huh?
Just a FYI .
Don't the 6 bolt heads add displacement?
jrhagen is offline   Reply With Quote
Old 07-15-2014, 08:09 PM   #7
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
no
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-15-2014, 08:43 PM   #8
jrhagen
Banned
Drives: Camaro
Originally Posted by Pro Stock John View Post
no
Seriously?!
Old 07-15-2014, 08:47 PM   #9
Pro Stock John
Writer
Seriously.
The 6 bolt heads use more head bolts, and have better clamping force as a result.
Engine displacement (size) is a formula. Bore X stroke.
PROJECT HEAVY CHEVY
Old 07-15-2014, 08:49 PM   #10
jrhagen
Banned
Drives: Camaro
Guess I will cancel my order.
Old 07-15-2014, 08:50 PM   #11
Da Mammer
Drives: 2010 camaro SS... shell...
Originally Posted by jrhagen View Post
Seriously?!
Seriously. Cubic inches is based on bore, stroke, and how many cylinders. NOT anything to do with heads, or pistons.
COMPRESSION is based on heads and pistons.... If that's what you may have been thinking?...
tried LSXTC...now I'm LSXOD...
Da Mammer is offline   Reply With Quote
Old 07-15-2014, 08:52 PM   #12
jrhagen
Banned
Drives: Camaro
So surfacing the heads doesn't change the displacement?
Old 07-15-2014, 09:13 PM   #13
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Heads have nothing to do with engine displacement. Maybe you are thinking of compression ratios.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-15-2014, 09:34 PM   #14
jrhagen
Banned
Drives: Camaro
Just jacking with you.
4x3x8 is my favorite engine.
