12-25-2012, 05:01 PM | #1 |
Drives: 2010 Join Date: May 2010
Just installed the 4-gauge pack. Few questions..
My car hasn't been out for a few days, and it's been cold where I'm at.
The Volts and Oil Temp seem fine. However, at start up, the TRANS temp is reading 30 and the Oil Pressure is reading 70 psi. Curious if this is normal? |
12-26-2012, 07:42 AM | #2 |
That is also what I'm reading at start up for the oil PSI. What is your reading at operating temp at idle? I was surprised at the slow rate at which the oil temp raises.
What is worse, while I was changing my oil, I did the gauges. I thought I had put the filter in wrong as in off center, partially blocking the passage way. |
12-26-2012, 07:45 AM | #3 |
Drives: 2010 CAMARO ABM 2LT Join Date: May 2009
normal
12-26-2012, 08:57 AM | #4 |
normal.
12-26-2012, 09:58 AM | #5 |
Thanks guy. So what are some reads that aren't normal with the gauges?
12-26-2012, 10:18 AM | #6 | |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
Sent from my iPad using Tapatalk HD |
12-26-2012, 11:19 AM | #7 |
oil pressure will go down after it warms up.
12-26-2012, 12:37 PM | #8 |
That Cam though...
Drives: 11 Camaro 2SS 02 T/A WS6 15 SSV Join Date: Mar 2010
yea they are not really accurate lol
