07-14-2014, 04:48 PM | #1 |
Drives: 1969 Chevrolet Camaro Join Date: Jun 2014
2013 Camaro SS Rear Suspension Parts 6k Miles
I have a rear suspension cradle from a 2013 Camaro SS with 6k miles. The parts that are not there are the differential, axles, knuckles, and calipers. Upgrade your V6 model to SS parts or replace worn parts you have now with low mileage OEM parts. Everything is good shape. Parts that are available:
Rotors (very, very little wear) **SOLD** Suspension cradle $100 Sway Bar w/ links **SOLD** Shocks w/springs and mounts $120 pair All suspension links $20 each (RH toe link sold) Or $420 for everything. Thanks! Last edited by silver69camaro; 07-25-2014 at 04:09 PM. |
07-14-2014, 09:31 PM | #2 |
Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
Will the cradle fit a 2010?
07-14-2014, 11:01 PM | #3 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Yes. The 2013 will upgrade your 2010 to the newer FE4 style sway bars (better), but is otherwise identical to the stock 2010 SS cradle.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
07-14-2014, 11:20 PM | #4 |
Will I still be able to use my SLP/Eibach sway bars?
07-15-2014, 07:47 AM | #5 |
07-15-2014, 10:10 AM | #6 |
2010 2SS/RS M6
I believe the newer lower control arms accommodate the older sway bars/end links, but I would recommend upgrading them to the FE4-style bars as well and selling your older bars.
07-15-2014, 01:46 PM | #7 |
Sway bar and links sold.
07-16-2014, 12:17 PM | #8 |
Drives: 2012 1SS/RS Join Date: Jun 2013
PM sent on rear rotors.
"Driving is the only thing I love about f1."
(Kimi Raikkonen) |
07-16-2014, 12:51 PM | #9 |
07-17-2014, 01:52 PM | #10 |
Rotors are sold.
07-21-2014, 08:19 PM | #11 |
IG @arod221_L5P
Drives: 2020 RGM ZL1 M6 Sroof 1 of 2 built Join Date: Aug 2012
i need the passenger side toe rod if its still available.
My Build Threads
2013 AGM 2SS/RS ***SOLD*** http://www.camaro5.com/forums/showthread.php?t=374535 2017 NGM ZL1 ***SOLD*** https://www.camaro6.com/forums/showthread.php?t=548637 ***COMING SOON*** 2020 RGM ZL1 M6 W/SUNROOF 1 OF 5 EVER BUILT W/ M6 & SUNROOF |
07-24-2014, 04:55 PM | #12 |
07-25-2014, 04:09 PM | #13 |
RH toe link sold.
08-07-2014, 02:15 PM | #14 |
Drives: 10 Procharged SS Join Date: Oct 2009
Shocks with springs still available?
