08-11-2019, 12:59 PM | #1 |
Drives: 2011 camaro ss Join Date: Apr 2011
Powermaster 9509 starter 2011 LS3
I tried installing this in my 2011 SS but the stock starter has a plug in solenoid wire and this one is a conventional nut bolt style.
Anyone have experience with this? Is there a pigtail that can be purchased so the original wire doesn't have to be cut? Thanks |
08-11-2019, 02:57 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
I installed the same starter on my ZR1. I just cut the OEM end off and crimped on a ring.
A more labor intensive option is to make a female plug that matches the OEM and install the ring on the other end. Then you would just plug the two in together. The easiest thing to do is cut the OEM one off, leaving enough wire in case you ever wanted to put it back together. |
08-11-2019, 05:44 PM | #3 |
Yea, I was trying to avoid cutting the connector off. Might have to splice into it if I can't find the proper end.
08-12-2019, 07:09 PM | #4 |
old school chevy rodder
The stock end is garbage anyway and prone to not connect well... also the starter has to be clocked and the main power wire bent to connect to the starter. You need to clear the sensor that comes out the side of the pan.....
08-18-2019, 12:51 PM | #5 | |
After these hurdles the starter does work great and I'm no longer getting slow cranking with the occasional service stabilitrak. |
08-18-2019, 12:59 PM | #6 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Can you share where you sourced the OEM pigtail connector? Thanks.
More to come. |
08-18-2019, 01:38 PM | #7 | |
https://www.eficonnection.com/home/S...ssSearchForm=+ EFI Connection, LLC Email: help@eficonnection.com Website: eficonnection.com |
08-18-2019, 03:11 PM | #8 | |
SomeguyK
More to come. |
08-18-2019, 08:33 PM | #9 |
08-19-2019, 06:56 AM | #10 |
Well that's one big connector...LOL But glad you tried the starter so you could report as I have it solves hot starting problems...…..
08-19-2019, 09:38 PM | #11 |
09-07-2019, 09:39 AM | #12 |
Thank you for your feedback...…. others may read this.....
09-07-2019, 10:21 AM | #13 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Link doesn't work.
Orange Krush II
04-09-2020, 03:51 PM | #14 |
Drives: 2012 1SS M6 IOM Join Date: Dec 2012
Just a update on the EFI wire.
In the search box, just type in "starter", and scroll down. here is the link https://www.eficonnection.com/home/p...rters-6-inches
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018. |
